31st Jul 2013, 9:54 pm | #1 |
Pye P45 (1950)
This set was one of a job lot of five I picked up a couple of weeks ago, I was saving them for winter, but as the weather has been lousy this week I decided to restore this set.
It was sort of working, but was quiet and distorted, so I started by removing the chassis, this is really easy job, pull off the knobs and remove two screws at the rear, unplug the speaker and the chassis slides out. The only sign of previous repairs was the volume pot had been replaced many years ago, all components and valves were the originals. I gave the chassis a good clean with a paintbrush and a Hoover, followed by white spirit on a rag. I replaced the usual suspect caps, using trader sheet 1085 as a reference. I still had distorted audio, but as the EL41 looked awful with much silvering and stains, this was replaced and the set now sounded good. A check on the resistors showed all were still in tolerance, the electrolitics were also fine, as was all the wiring. I stripped the cabinet of the dial glass and speaker baffle and went over the cabinet with T-cut, this removed decades of dirt and paint spots and brought the finish up a treat, I gave the cabinet a good going over with Topps scratch cover, the dial glass was cleaned and the speaker mesh was scrubbed clean and refitted, and a new pair of dial bulbs were fitted after cleaning the light tray. The chassis was refitted along with the knobs, these came up really well with a good clean and a final polish with T-cut. I really like these Pye short superhets, they work very well and sound good too, this one has come up a treat, it is a real shame that the scratches on the cabinet are recent, other than that the set is in remarkably good condition for it's 63 years, and works very well on all wavebands. All told this set took around six hours from start to finish, and was a joy to work on. Mark |
31st Jul 2013, 10:00 pm | #2 |
Re: Pye P45 (1950)
And the after photos....
31st Jul 2013, 10:14 pm | #3 |
Re: Pye P45 (1950)
Beautiful job.
31st Jul 2013, 10:57 pm | #4 |
Re: Pye P45 (1950)
remarkable restoration to one of these often overlooked sets.
Stephen |
1st Aug 2013, 10:19 am | #5 |
Re: Pye P45 (1950)
Looks like new again!
Robert |
1st Aug 2013, 10:13 pm | #6 |
Re: Pye P45 (1950)
And all in only 6 hours!
1st Aug 2013, 10:47 pm | #7 |
Re: Pye P45 (1950)
Thanks for the positive reply's chaps, it really has been a pleasure to restore this set, the cabinet has turned out better than I hoped, these sets are really well made. when cleaning the chassis I came across a few places where the chassis paint had been touched up during manufacture, a good sign that these sets were built to a high standard.
I agree that these sets are overlooked, this one had been well used and would probably work even better for replacing the valves, but the fact it was basicly still working after 63 years is a testament to the quality of the set. It is now sitting next to my Pye LV51F TV from the same year, I really like the way Pye built their sets, And am happy to have added this set to my collection. Mark |
2nd Aug 2013, 9:26 am | #8 |
Re: Pye P45 (1950)
Just to echo what the others have said, you've done wonders there! The cabinet looks like it's just left the factory, the chassis too.
I had a slightly earlier version with octal(?) valves and only 3 wavebands, think it was the model 15, but the cabinet was very tired compared with yours. I seem to remember the knobs were surprisingly fragile, maybe because the switches were stiffer than they should have been. I think I passed it on to Paul Sherwin soon after I joined the forum. Keep up the good work, Nick. |
2nd Aug 2013, 9:58 am | #9 |
Re: Pye P45 (1950)
Painted chassis always look nice after a spruce up - It seems that the companies that painted chassis made quality goods!
Pye (obviously), Hacker and many others are throwback to a better era (in my mind) Lovely job - excellent result SEAN
There are only 10 types of people, those who understand the binary system, and those who don't. |
2nd Aug 2013, 10:31 am | #10 |
Re: Pye P45 (1950)
It was an 18A. Pye were very keen on the short superhet concept and used it in most of their 40s and 50s products, including in unlikely things like radiograms and multiband SW sets. They do work surprisingly well even with a frame aerial, though the lack of gain is obvious on weaker stations.
2nd Aug 2013, 10:49 am | #11 | |
Re: Pye P45 (1950)
Mine also needs the cabinet refinishing, but works very well. There was a problem with the plastics that were used for the knobs, I have seen them go white and distorted as well as looking as they had been in a fire! There were quite a few variations of these Pye short superhets made from 1945 onwards, all in plain simple cabinets, but this set has really nice bookmatched veneers that really lift the appearance of the cabinet. Pye and Bush are my favourite manufacturers, followed by Murphy (more lovely blue chassis) and Ultra. The next set on the bench will be the truly massive prewar RGD 66, but there is a lot of rotten wiring to deal with and the cabinet will have to be refinished and I will be restuffing all the caps. Mark |
2nd Aug 2013, 12:08 pm | #12 |
Re: Pye P45 (1950)
Good job Mark!
Colin |
10th Aug 2013, 11:31 am | #13 |
Re: Pye P45 (1950)
Nice job! That venneer finish really does have 'depth' to it.
12th Aug 2013, 4:23 pm | #14 |
Re: Pye P45 (1950)
That does look nice, a great job.
Simon BVWS member |
12th Aug 2013, 4:31 pm | #15 |
Re: Pye P45 (1950)
Excellent job!. The last one of those I saw was from a farmers barn and had been home to several generations of mice!
27th Oct 2014, 11:26 pm | #16 |
Re: Pye P45 (1950)
Just finishing off the second one of these I've restored - photo of the first one attached. They reall can come up very nicely if you Nitromors the varnish off, rub the cabinet down and re varnish it!
This one - which I'm restoring for my son - has rather worn legends on the wave change and gram/tone switches (the other 2 are OK) which are not responding well to my usual "gold pen and rub it down when dry" trick. Any ideas? And - any point in trying to construct an internal frame aerial a la P75?? Bryan |
28th Oct 2014, 9:37 am | #17 |
Re: Pye P45 (1950)
The quality of the knobs Pye used varies wildly, some distort badly, some are fine. I think the depth of engraving is also variable, this could be the problem with yours.
Before trying to renew the paint, I always use a sturdy sewing needle to remove any dirt and old paint. Mark |
28th Oct 2014, 10:55 am | #18 |
Re: Pye P45 (1950)
Thanks, but sadly, the depth of the engraving in places is zero! I'm reluctant to try to dig into the plastic to recreate the letters....
28th Oct 2014, 11:26 am | #19 |
Re: Pye P45 (1950)
The replacement polyester capacitors you used have certainly merged unobtrusively with the original components.
Mike |
28th Oct 2014, 11:36 am | #20 |
Re: Pye P45 (1950)
Ah - I think you're looking at Mark Pirate's radio, not mine!!!
