Old 27th Oct 2018, 1:21 pm   #1
Kevin Hoyland
Default Racal Dana 9917A
Hello.
My Racal Dana 9917A as just stop working. It lights up with all 8s a cross the Display. when I apply a signal to the 2 inputs A and B it will not read the signal.
I have not been able to get my hands on a service manual in the last 2 years. It maybe a ICTL 081CP that as given up.
Regads
Kevin
Kevin Hoyland is offline
Old 27th Oct 2018, 1:45 pm   #2
Station X
Station X's Avatar
Default Re: Racal Dana 9917A
Have you tried the Racal-Dana yahoo group?
https://groups.yahoo.com/neo/groups/Racal_Dana/info
Graham. Forum Moderator
Station X is online now
Old 27th Oct 2018, 1:50 pm   #3
Station X
Station X's Avatar
Radio Museum has a circuit:-
https://www.radiomuseum.org/r/racal_...9917a9917.html
Old 27th Oct 2018, 7:24 pm   #4
WME_bill
Racal 9917-9918. Part of the 9910 series from 1984/5. I attach a extract from the Racal catalogue and specification, which suggests that the 9917A and 9918 are virtually identical.
I have the 9921, a later extension of the 9918 with a channel C which goes up to mid Ghz and in a wider case, to accomodate the extra channel and divider panel.
I think that "k04bb" has the 9918 manual on his invaluable web site. It is sometimes a bit touchy to download. If you are stuck, then I will scan my copy of the 9918/9921 but there will be some delay as it is a very large manual. Though not a much as the two years search you mention.
wme_bill m0wpn
File Type: pdf Racal 9917A-9918 Counters-cat1984-5-wm.pdf (1.34 MB, 152 views)
WME_bill is offline
Old 27th Oct 2018, 9:06 pm   #5
PETERg0rsq
PETERg0rsq's Avatar
I have a copy of the technical manual and schemetics
Not sure where i got it from, possibly someone on here.
More than happy to send a copy to you if you PM me with an e-mail address
Not the best copy but perfectly useable.
Peter
SPECIALIST.....Knows everything about nothing
EXPERT..........Knows nothing about everything
PETERg0rsq is offline
Old 28th Oct 2018, 10:37 pm   #6
karesz*
Kevin,
you can have 9918 & 21 manuals from here...
rgds, Karl
karesz* is offline
Old 29th Oct 2018, 8:36 am   #7
Kevin Hoyland
Hello and Good morning. Thank you to Graham/WMB-bill/Peter/Karl for taking the time to help me. Peter I will send my email address to you for the Manual and Scheamatic.
Regards
Kevin
Old 30th Oct 2018, 9:32 am   #8
Kevin Hoyland
Hello and good morning.
Peter has sent me the full manual by email.
A big thank You to Peter and all that have taken the time to help me.
Kind Regards
Kevin.
