Old 31st Dec 2013, 10:19 pm   #1
don200002
don200002's Avatar
Default Rejuvenating Magic eye Valves?
Can someone please tell me would it be possible to rejuvenate Magic Eye Valves in a similar way that we used to rejuvenate TV tubes?
Thanks,
Don.
don200002 is offline
Old 31st Dec 2013, 10:36 pm   #2
Sean Williams
Sean Williams's Avatar
Default Re: Rejuvenating Magic eye Valves?
I would say not, the target actually gets stripped of it's emmissive ability, cranking the heater volts up would give a limited increase in brightness, but not for very long.
Sean Williams is offline
Old 31st Dec 2013, 11:56 pm   #3
mark pirate
mark pirate's Avatar
Yes, No chance I am afraid, I need 3 Y63 and a couple of TV4 and a TV6.
NOS eyes are getting very expensive, and I don't want to pay more for the valve than the set is worth!
I have avoided used valves because they probably have no emission left
There was a thread on LED replicas recently, so there is an alternative.
Mark
mark pirate is offline
Old 1st Jan 2014, 12:47 am   #4
don200002
don200002's Avatar
Thanks for the replies, I guesed as much due to the price of replacements, I suppose the only way to improve the performance is to up the heater or target voltage but thanks for all your help,
Don.
Old 1st Jan 2014, 4:41 am   #5
Maarten
As long as the problem is in the cathode rather than in the emissive layer, any valve can be rejuvenated with varying degrees of success. It never hurts to try!
Simplest test could be to let it glow at an elevated heater tension (for example 8V instead of 6,3V) for a few minutes. Then plug it back into the set and see whether there is any difference at all. If there is, some improvement should be possible. Also if the valve is operated at a higher heater tension while in the set (or in a test setup) and the eye is much brighter at 8V this shows the emissive layer still has some life left.
Maarten is offline
Old 1st Jan 2014, 11:27 am   #6
Phil G4SPZ
Phil G4SPZ's Avatar
I've read a couple of articles which suggest that the only way of getting more life out of tired eyes is to increase the target voltage, up to 500 volts. There is an article in the latest NZVR Bulletin with a suitable voltage doubler design. Coupled with reducing the heater voltage by 20% or so, a greatly extended life is claimed for both old and NOS eyes.
Phil
Phil G4SPZ is offline
Old 1st Jan 2014, 12:03 pm   #7
GMB
GMB's Avatar
I note that there has been some research done on rejuvenating electroluminescent displays which are using a very similar phosphor, and this suggests that annealing at a temperature of between 180C and 240C does significantly help (maybe takes about 2 hours, and the temperature is fairly critical - don't overdo it).
GMB is offline
Old 1st Jan 2014, 1:17 pm   #8
boxdoctor
I wonder if the loss of brightness is always entirely due to loss of emission by the cathode.
It could be that the phosphor coating on the target might be deteriorating. Targets often look discoloured in the illuminated area. In that case, it would be very difficult to ever achieve the original brightness.
boxdoctor is offline
Old 1st Jan 2014, 1:36 pm   #9
turretslug
turretslug's Avatar
They do seem to go to a dull grey from the initial light appearance- yet the heat of a mA or so of HT on the metal cone/crescent must be negligible. Is there some sort of chemical combination/poisoning going on with the base metal?
It's a shame they are short-lived, I'm sure if there was a simple answer, the proverbial army of tinkerers would have found it. At least the low current requirement suits straightforward voltage doubling, heater boosting takes a bit more thought. It rings a bell that some posh sets with variable selectivity only switched eye HT on in "narrow" for tuning, removing it on "fidelity" positions. Perhaps a subtlely hidden switch for show use would eke out these increasingly scarce and pricey beasties.
I have a couple of tired EM81s around, the oven idea is tempting on the grounds that there's not much to lose!
turretslug is offline
Old 1st Jan 2014, 2:26 pm   #10
Maarten
On a Dutch forum, there has been some discussion about rejuvenation using a few seconds of microwave exposure at a few hundred watts. It seemed to work sometimes and blow the heater on other occasions. Maybe GMB is on to something and there is some limited effect on the emissive phosphor layer as well.
In my earlier post, I used the words emissive layer as well, but omitted the word phosphor. I'm sorry for any confusion.
Maarten is offline
Old 1st Jan 2014, 2:34 pm   #11
cmjones01
That's an interesting idea - it should be easy enough in a domestic oven. Can you point us to any of the research?
Chris
cmjones01 is online now
Old 1st Jan 2014, 2:34 pm   #12
neutronic
neutronic's Avatar
I don´t feel responsible !!!
And I don´t apologize to your wive.
Some euphoric stories about putting them in the microwave!
Only for a very short moment.
Half of them are as good as new and half of them explode.
http://www.gloeidraad.nl/radioforum/index.php?id=140756
(translation by Google?)
a very Happy 2014
Jard N.
neutronic is offline
Old 1st Jan 2014, 3:19 pm   #13
mark pirate
I have found the Thread on Replica magic eyes, click the link in post#1.
https://www.vintage-radio.net/forum/...ead.php?t=8123
Mark
Old 1st Jan 2014, 3:56 pm   #14
Still sounds well worth a try, what's to lose- a useless magic eye?
And maybe a sweep out of the microwave before SWMBO catches you at it
Herald1360 is offline
Old 1st Jan 2014, 4:16 pm   #15
turretslug
turretslug's Avatar
With a shorting twist of wire across the heater pins. (Though a well-known law says that that would form a resonance.)
Old 1st Jan 2014, 4:35 pm   #16
Phil G4SPZ
Phil G4SPZ's Avatar
The Dutch report mentions 3 seconds at 900 Watts, or 2,700 Joules.
I have a very old 700 Watt microwave oven, due to be scrapped next month, and a pile of dim eyes, so I will definitely give it a try at about 4 seconds.
Phil
Old 1st Jan 2014, 5:03 pm   #17
mark pirate
Please let us know how you get on Phil, I have a few that are very dim, and a couple that have no display at all!
Mark
Old 1st Jan 2014, 5:15 pm   #18
don200002
don200002's Avatar
I have an EM35 with no display at all, 3 seconds at 850 watts and there is a very dim display.
P.S. I did take the precaution of putting it in a bubble wrap bag before "cooking".
Best of luck,
Don.
Old 1st Jan 2014, 5:36 pm   #19
GMB
GMB's Avatar
No, it hardly ever is that.
The thing that is really interesting about magic eyes is that it is the ones with metal luminescent targets that fail badly.
The EM84 and similar last way longer.
The anode current tells you that it isn't a cathode problem.
The same type of failure occurs in the radioactive dials on old military equipment. They also used ZnS phosphor but this time activated by the radiation. They usually don't glow at all by now (but are still radioactive).
There are really only two possible ways that phosphors stop working. It is either because the "activator" is not working, or because they are contaminated by something that takes the energy away better than the ZnS. The common green ones are probably ZnS and copper and I think they work by the copper catching the energy and passing it to the ZnS to emit the light.
There is unfortunately a real possibility that the damaging mechanism is metal evaporating from the cathode and embedding in the target causing the energy to be diverted away from the emitter. This may be hard to fix although I wondered about creating a high voltage discharge with the target as cathode. The other reason, which the heat suggestion addresses, is that the copper activator diffuses into the ZnS and the structure no longer works properly - but can be restored by heat.
The microwave suggestion could work in either of these ways - but a more controlled method might give clearer results. But there is little to loose.
GMB is offline
Old 1st Jan 2014, 6:46 pm   #20
audiomagpie
audiomagpie's Avatar
Someone (and I'm sorry, I can't remember who) was selling and demonstrating LED ones at the last Golborne meeting. I was so impressed, I bought an EM34 version but haven't fitted it as yet.
Maybe someone else was there and know's who it was?
Greg
Greg
BVWS committee chairman
audiomagpie is online now
