4th Jan 2017, 5:09 pm | #61 |
Re: Vidor CN430 fading out during use.
C3 and C10 appear to be there, the ringed rat t**ds.
Lawrence. |
4th Jan 2017, 5:17 pm | #62 |
I don't have the Trader sheet so the ref numbers are no use to me. However there are 2 caps under the waxy (why haven't you changed that one?) that look like resistors - except they are caps. Brown body with stripes round them which are probably what you are referring to.
If you quote the value of the part as well as the circuit ref then I might be able to equate it to the drawing I have from the R & TV books. |
4th Jan 2017, 5:19 pm | #63 |
Mixer screen feed = 120k, Osc anode feed = 33k.
Lawrence. |
4th Jan 2017, 6:17 pm | #64 |
Ah thanks. I didn't recognise those as caps.
http://www.crutchleyhistory.co.uk/ |
4th Jan 2017, 6:17 pm | #65 | ||
4th Jan 2017, 10:07 pm | #66 |
Thank you Lawrence,
That was the area I was looking in, I will check those resistors. Best regards, Gary
4th Jan 2017, 10:08 pm | #67 | |
V1 oscillator anode voltage is too high and, with the grid being 5 volts positive rather than negative, it all suggests that the valve isn't conducting, never mind the oscillator not running. Is the DK96 a known good valve? I still think your low filament voltages are the root cause.
4th Jan 2017, 11:06 pm | #68 |
I am not sure if this has been mentioned already but battery valves are directly heated which means the valve anode and screen currents pass through the heater chain. The parallel resistors across each of the filaments ensures the filament voltages are correct when the valves further down the chain are running at the intended anode/screen current.
It is therefore critical that all leaky capacitors are replaced and resistor values checked before you come to any conclusion on the filament voltage issue. I am not sure if it has changed but for the low V1 SG volts you should check R2 (120K) and C3. The total LT current of 25.7mA in the trader I presume is the current that passes through R21/R20. Once you are confident you have sorted out the components you should break the connection between R20/R21 and adjust R21 for 25mA. You should then measure the individual valve filament voltage to check they are all OK. |
4th Jan 2017, 11:40 pm | #69 | |
The set is not operating, you are correct. However, it appears that it has HT and LT, albeit not the correct voltages in some areas. I did manage to set the current initially, then re-soldered the connection before measuring the voltages I posted. Of course something could have changed after I reconnected the resistor. As yet I haven't checked C26, C25 and C24, I don't have a method to check for leakage so I would have to change them. I was planning to order some 0.1uF caps and deal with the waxies first before the electrolytics. One at a time of course. I have measured the filament voltages between pins 1 and 7. I need to measure the V1 grid potential between pins 4 and 1, I haven't done that. I tried the DK96 from my Ultra which works well, it made no difference unfortunately. I agree that the low filament voltages are likely to be the problem. Many thanks for your help yet again. Gary
http://www.crutchleyhistory.co.uk/ Last edited by gary_crutchley; 4th Jan 2017 at 11:47 pm. Reason: Extra information. |
4th Jan 2017, 11:43 pm | #70 | |
Many thanks for your help, I appreciate it. I will make the checks that you suggest and report back. Best regards, Gary
6th Jan 2017, 12:03 pm | #71 | ||
6th Jan 2017, 5:30 pm | #72 |
Thanks Phil, that's excellent. C25 and C25 are 0.1uF, I don't have any of those so I will order some and exchange them one at a time to see what effect they have. If that doesn't help I'll move on to the electrolytic C26. Thanks again for all the help.
6th Jan 2017, 6:58 pm | #73 |
I would suspect the electrolytic first! If you don't have a replacement, I could probably find you one, together with the two 0.1uFs.
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 6th Jan 2017 at 7:00 pm. Reason: Typo |
6th Jan 2017, 7:52 pm | #74 |
Hi Phil,
I looked at the electrolytic, it is 100uF 26V DC. Would these be suitable: http://www.ebay.co.uk/itm/Radial-Alu..._FhEXMv28sOJTQ They do 100uF at 25 and 35V. Regards, Gary
6th Jan 2017, 10:02 pm | #75 |
Yes Gary, those would be ideal. The 25 volt one would probably be fine, as the actual voltage across the capacitor in circuit under normal conditions is less than 10 volts, but as the usual advice is to fit a replacement with the same or higher working voltage, you could play safe and go for the 35 volt one. The cost is very reasonable either way.
6th Jan 2017, 10:23 pm | #76 |
Many thanks Phil. Thanks for offering to help with the components, I am grateful but I don't think I should keep using you stock.
6th Jan 2017, 10:59 pm | #77 |
Over the years, I have acquired and been given literally thousands of components, and I'm quite happy to offer to share them with other restorers because I recognise that I will never use more than a tiny fraction of them myself, no matter how long I live! However, if you are tackling vintage radios on a regular basis, Gary, it helps to have a few of the more common components in your own stock, like resistors and capacitors and maybe a few valves. When you need one or two, buy ten and put the rest into stock. That way, you build up a good stock relatively cheaply.
For what it's worth, I've just taken delivery of twenty 0.01uF 630 volt capacitors specifically for the restoration of a friend's Eddystone S640. The cost of the components was around £8, including postage, and what I don't use I'll put into stock. If you change your mind, I'll be at the Museum next Wednesday and can bring whatever you need along with me. And you're right, it's C26 not C24 that's the electrolytic! Silly me
Phil Optimist [n]: One who is not in possession of the full facts Last edited by Phil G4SPZ; 6th Jan 2017 at 11:02 pm. Reason: Error |
6th Jan 2017, 11:27 pm | #78 |
Hi Phil,
Again I thank you for your offer, but I agree with you that I need to build up a little stock. Also I'm not the only person you might want to help in this way. I ordered 10 each of the electrolytics and the 0.1uF caps, they are actually quite reasonably priced. By the way, your Avos are performing superbly. Thanks again Phil.
6th Jan 2017, 11:31 pm | #79 |
Phew, that's a relief!
6th Jan 2017, 11:32 pm | #80 |
Never in doubt, you did a great job with them.
