Old 20th Jan 2020, 6:53 pm   #1
Final anode
Default JRC JST-135 Vfo knob removal
Hi
I am taking off the front to change some of the tact switches on my JST-135, does anyone know the hex key size for the VFO knob, 1.5mm seems a loose fit and I wouldn't have thought it was 1/16, don't want to risk breaking it.
Final anode is offline
Old 20th Jan 2020, 9:04 pm   #2
g4aaw pete
g4aaw pete's Avatar
Default Re: JRC JST-135 Vfo knob removal
Hello Dave
I don't have the definitive answer, but:
Kenwood TS830 = 2mm
Kenwood R5000 = 1.5mm
just as a point of reference!
Pete
g4aaw pete is offline
Old 20th Jan 2020, 11:01 pm   #3
Final anode
1.5 feels sloppy as though it's going to damage the key or the grub screw, if the grub gets damaged it's trouble! Will get a 1/16 which is 1.588mm, 2mm is to big
Thanks
Dave
G4OSY
Old 21st Jan 2020, 1:17 am   #4
jonvk2fsw
HI the hex key you need 1.45 mm or 57.5 thou . A very odd size but I just checked the one on my nrd525 knob .all the best JON VK2FSW PS a 1.5 mm may fit but seems very tight
jonvk2fsw is offline
Old 21st Jan 2020, 6:56 am   #5
Radio1950
Hi there,
I just checked, and my JRC NRD515, an earlier receiver, has knobs with 2.00mm AF "allen type" grubscrews.
Imperial 5/64 inch also "feels" correct size, but I am sure that my knobs would be 2.00mm ex factory.
This would correlate with your finding that 1.5mm AF is 'loose".
May not be applicable to your knobs, so double check.
Very good luck to you.
Radio1950 is online now
Old 21st Jan 2020, 6:42 pm   #6
Final anode
Thanks everyone, I got it off! A 1/16" 1.588mm fitted perfectly but it still wouldn't budge! So I used a piece of 10 gauge wire put it into the hole and the hex key head, I then heated the wire with a soldering iron being careful not to catch the plastic, heat conducting down to the grub did the trick, JRC must have used various size grub screws during production, got the pcb off now to change the faulty tact switches, BTW its a fantastic rig, superb receiver, has the 240hz filter which is too narrow looking for a 500hz, read some were you can use Kenwood or Icom, can anyone confirm?
Old 21st Jan 2020, 9:15 pm   #7
g4aaw pete
g4aaw pete's Avatar
Think the orientation of the in / out pins may be differnt.
Shown is the underside of a Kenwood filter.
Pete
Old 21st Jan 2020, 10:49 pm   #8
Final anode
Yes Pete thanks, the JRC is in line & 2 threaded studs, it's the Icom I think fits but the grounds are soldered the FL52A somewhere I've seen it mentioned online, not sure on the impedance though, probably better of waiting for a JRC one to pop up on ebay.
