20th Apr 2016, 6:20 pm | #1 |
Linn on TV
Nice to see the Linn factory and some of the operations involved in making the famous Son deck.
Absolutely no inside real information but was a good watch on Quest "how it works" last night. Gary |
20th Apr 2016, 7:03 pm | #2 |
Re: Linn on TV
I wonder if it will be on their catch up type player?
21st Apr 2016, 9:40 pm | #3 |
Re: Linn on TV
21st Apr 2016, 11:43 pm | #4 |
Re: Linn on TV
Thanks for the link to the video. That's certainly how turntables should be built. A quality product built by people that take pride in their work not like the junk turntables in a previous thread.
Symon. |
21st Apr 2016, 11:51 pm | #5 |
Re: Linn on TV
Interesting stuff.
I'm sure turntables don't all need to be made to such high standards, but I'm as there's a real 'top end' of the industry still. They just need to show the actor how to play a record from the start rather than half way through. |
22nd Apr 2016, 6:12 am | #6 |
Re: Linn on TV
Vinyl seems to have become a noun for a specific item made from the material formerly meant by the word 'vinyl'
22nd Apr 2016, 6:37 am | #7 |
Re: Linn on TV
As in 'I've just bought a vinyl'? Yes, that irritates me. Also the idea that the 'vinyl sound' must have crackle.
Nice to see a piece of kit being made that makes the absolute most of the format. The video at least might educate a few as to what goes into a real record player. |
22nd Apr 2016, 2:40 pm | #8 |
Re: Linn on TV
Is the mini amplifier being referred to a built in pre-amp? I was one told that turntables don't have built in pre-amps otherwise they would pick up noise from the motor?
22nd Apr 2016, 4:48 pm | #9 |
Re: Linn on TV
And the moving coil cartridge won't?
It's one of those tales which get repeated until they become true. One of the lesser bits of pseudoscience in the audio business. If you can screen one, you can certainly screen the other. The shorter cables are good, and the local mounting avoids ground loops through other equipment coupling into the very sensitive connection between cartridge and preamp. David
22nd Apr 2016, 5:03 pm | #10 |
Re: Linn on TV
Indeed. I would have thought that the length of RCA cable itself would impose a certain amount of loss which is not desirable. By having only a short wire from the stylus to the pre-amp you effectively eliminate that problem. I would expect good screening to eliminate any noise so I was rather puzzled by that assertion, but it was a long while ago and I was informed by people older and apparently wiser than me so I sort of filed that piece of information for future reference. It was therefore interesting to see that Linn fit a pre-amp directly into their turntable. You point about avoiding ground loops is also a good one.
22nd Apr 2016, 6:27 pm | #11 |
Re: Linn on TV
My Ortofon MC cartridge and screened cable pick up a low level burbling noise background from the Linn motor and/or its electronics. Must get round to fixing it sometime, but it's generally masked by the disc surface noise when actually playing.
Martin
BVWS Member |
22nd Apr 2016, 7:18 pm | #12 |
Re: Linn on TV
Philips and B&O definitely used to fit MM preamps into their better decks as an optional extra.
23rd Apr 2016, 9:02 am | #13 |
Re: Linn on TV
It's a moving-coil cartridge pre-pre-amplifier not an RIAA stage. It's only fitted to one of their current range of turntables. Strangely, when I looked at the "How it is made" programme about a turntable on Quest, it was about a completely different brand with a carbon-fibre tone arm.
23rd Apr 2016, 10:24 am | #14 |
Re: Linn on TV
Ah, thanks for the clarification.
24th Apr 2016, 8:34 pm | #15 |
Re: Linn on TV
The brand of turntable being manufactured in the programme is Wilson-Benesch.
Richard Brice has come up with an on-cartridge buffer for moving magnet cartridges which looks interesting - I'm playing with one at the moment. |
26th Apr 2016, 3:28 pm | #16 |
Re: Linn on TV
Yes, interesting to see two very different turntables discussed on two separate but similar programmes. I found the Linn one rather more convincing when it came to precision and quality.
26th Apr 2016, 4:20 pm | #17 |
Re: Linn on TV
Just don't take everything that Ivor Tiefenbrun says as being 'fact'. He makes a total fool of himself in test 9 here: http://www.head-fi.org/t/486598/test...aims-and-myths
