Old 22nd Feb 2020, 12:22 pm   #1
msf1344
Default Sony ICF-SW7600 FM problem
Hi folks
I have one of this Sony radio which is not good on FM band. When i search for any station its just skip. But it is perfect on AM. Anyone had similar problem. Thanks
msf1344 is offline
Old 22nd Feb 2020, 1:33 pm   #2
orbanp1
Default Re: Sony icf-sw7600 fm problem
The 7600 has several generations/versions.
Which one is your radio?
Best to post a picture!
Regards, Peter
orbanp1 is offline
Old 22nd Feb 2020, 5:36 pm   #3
msf1344
Default Re: Sony ICF-SW7600 FM problem
Hi. Its just a ICF-SW7600 which is the first product back to 80s. I will upload some pictures and also I took it apart and there is one picture of the main board.
ID:	199520   Click image for larger version
ID:	199521   Click image for larger version
msf1344 is offline
Old 23rd Feb 2020, 2:13 pm   #4
orbanp1
It looks like the 7600G, at least the "matching" service manual has that title.
(Mine is called a 7600D, it is earlier than yours, and it looks like the ICF-2002.)
Here is the service manual for the 7600G:
https://www.manualslib.com/manual/59...f-Sw7600g.html
Based on the schematics, pg. 13 in the manual, you need to follow the FM signal path and see where does the signal "disappear".
Regards, Peter
orbanp1 is offline
Old 24th Feb 2020, 1:31 pm   #5
Goldieoldie
Hi
Along with other Sony radios of this era they suffer from failure of the Ali can capacitors .
They leak their electrolyte which as well as affecting their capacitance etc can spread onto the PC tracks causing corrosion and electrical leakage where it's not wanted !
It can also get into coils causing them to go o/c .
If you look carefully at the bases of the caps your might see some leakage or corrosion of the solder lugs on the caps.
Also there might be a smell ,all tale tale signs of cap failure .
Check under the buttons on the PC for signs of leakage or liquid spill
Can be cleaned off with IPA
Pete
Goldieoldie is offline
Old 28th Feb 2020, 2:17 pm   #6
msf1344
Hi, please look at the attached photo. What is that yellow stuff around the transistor? Is it factory default?
msf1344 is offline
Old 29th Feb 2020, 6:14 pm   #7
Ken Taylor
Ken Taylor's Avatar
I had a problem with FM on my 7600D, turned out the wire to the telescopic aerial had come off.
Ken
Ken Taylor is offline
Old 29th Feb 2020, 9:42 pm   #8
Goldieoldie
That gunk is a glue that Sony used. It can cause problems in some circuits as it sometimes becomes conductive with age!
Old 5th Mar 2020, 10:57 am   #9
msf1344
How to remove it and is it safe to clean it ?
msf1344 is offline
Old 5th Mar 2020, 10:48 pm   #10
Goldieoldie
Use a wooden toothpick and some IPA
Be careful around coils and transformers as it's easy to damage the very thin coils
I don't think this is your problem though, far more likely the caps need changing.
