Old 9th Sep 2019, 1:37 am   #1
Nightcruiser
Default Early 1958 Bush SRP31 question update
Could the more experienced members of the group please help answer my question regarding the original 1958 SRP Bush record player.
When it comes to replacing the rectifier, what is the biggest difference between the original SRP31 chassis and the later model SRP31C/D
Which diode and resistor is currently recommended for using in this early model?
As I have *absolutely no prior experience* of updating and replacing a rectifier.
Could anyone please provide/upload clear photographs to this thread as to precisely how this is to be done or PM me with the information.
Many thanks.
John.
Nightcruiser is offline   Reply With Quote
Old 9th Sep 2019, 9:42 am   #2
John10b
Default Re: Early 1958 Bush SRP31 question update
Iím not sure of the difference between the two models.
The typical replacement components are: 1N4007 diode and a 330 ohm 5 watt resistor connected in series. The ht voltage is about 215 volts dc.
John10b is offline   Reply With Quote
Old 9th Sep 2019, 9:46 am   #3
Nuvistor
Nuvistor's Avatar
I think they changed the record player deck in the later version, both amplifiers seem the same.
Mount those components John refers to on a tag strip making sure you connect the diode the correct way round. Keep the resistor away from other components it will get hot.
Frank
Nuvistor is online now   Reply With Quote
Old 9th Sep 2019, 9:49 am   #4
John10b
Further to my post, I took a look at the service manual and at the back it said that the SRP31c is identical electrically but with a slight difference in the cabinet and different record deck fitted.
Old 9th Sep 2019, 10:06 am   #5
Many thanks.
John.
Here you go:-
https://www.vintage-radio.net/forum/...d.php?t=153857
Keep the soldering iron hot.
Old 9th Sep 2019, 10:55 am   #6
Michael Maurice
Michael Maurice's Avatar
Normally I remove the grey wire going from the transformer to the rectifier (usually grey) then mount the diode and resistor between the transformer tag where the grey wire was and the capacitor can’s tag nearest the edge of the chassis.
Forum Moderator
Michael Maurice is offline   Reply With Quote
Old 9th Sep 2019, 12:22 pm   #7
Edward Huggins
Be aware that there's quite a difference between the BUSH SRP31C and SRP31D.
Edward.
Edward Huggins is offline   Reply With Quote
Old 9th Sep 2019, 1:39 pm   #8
Is that relevant to the OP's query?
Old 9th Sep 2019, 2:56 pm   #9
John10b
Edward will you tell us the difference please, thank you.
Old 9th Sep 2019, 4:14 pm   #10
Nuvistor
Nuvistor's Avatar
/D 2x ECL86
/C 2x ECL83
Frank
Old 9th Sep 2019, 4:55 pm   #11
John10b
Thank you Frank.
Old 9th Sep 2019, 7:26 pm   #12
Edward Huggins
Also they employ a different autochanger and cartridge in each version.
Edward.
Old 9th Sep 2019, 8:20 pm   #13
Is the existing rectifier located in the same position as in the non-suffixed models? That's what's important to the OP who's seeking detailed instruction as to how to replace it.
See the thread linked to in post #5.
Old 9th Sep 2019, 8:23 pm   #14
AC/HL
AC/HL's Avatar
In this instance we're only concerned with the HT rectifier though, which is the same selenium unit. As said, replace it with a silicon diode and a resistor to bring the HT to approx the same. I used the same method as Michael in post 6, but the only requirement is a good constructional technique it's only two components.
Edit: crossed!
Bill, BVWS member
Old 9th Sep 2019, 8:40 pm   #15
Nuvistor
Nuvistor's Avatar
This is info on the SRP31 and 31C, I donít have under chassis layout information for the /D.
The differences described for the 31 and 31C are record deck and pickup cartridge.
The amplifier is identical using ELC83 valves in push pull.
The SRP31D with ECL86 valves has a similar upper chassis layout, I canít confirm underside, be surprised if layout was a lot different.
Frank
Old 9th Sep 2019, 8:58 pm   #16
I guess we need a picture from the OP showing the existing rectifier and wiring.
I thought the OP had asked a simple question which merited a simple answer. How wrong I was, 16 posts and counting!
Old 10th Sep 2019, 12:03 am   #17
Michael Maurice
The circuit is more or less the same between the two versions (ECL83/86) but the pin outs on the valves are different. I think ECL86 was more reliable.
Rectifier and smoothing circuits exactly the same on both.
Forum Moderator
Old 11th Sep 2019, 3:34 am   #18
Nightcruiser
Thank you John. That has been very helpful.
