19th Apr 2019, 3:19 pm | #21 | |
Re: RF probe to work with amplified speaker
I used the same set up a few years later to fault a radio board I bought second hand. I'd got two- neither worked, but one had a problem in an IF transformer. Transformer changed- set worked for years, as part of a stereo system I built. |
19th Apr 2019, 3:41 pm | #22 | |
Link working for me. John. |
19th Apr 2019, 5:27 pm | #23 |
Thanks I'm re-enthused, some really usefull information there, Thanks for all your replies. I've read and read about things but in the end for me I really have to do things before they sink in properly. Experience ultimately means you do less unnecessary things to get to an end point but to get that experience you have to do things you later realise might not have been necessary. So I suppose it becomes necessary to do unnecessary things while you are learning. Time for procrastination is over, fingers crossed I'm going in...might wait till tomorrow and read a bit more about it first though! BTW I'm making a box to connect my signal generator to with 2 x boc connectors so I can connect it to my frequency counter and the set at the same time with banana plug sockets also as I have some. What value blocking capacitors should I use in it?
19th Apr 2019, 5:38 pm | #24 |
Yep...link is OK now.
19th Apr 2019, 7:59 pm | #25 |
Printed out from link and think it will be really useful to me. Thanks David much appreciated.
19th Apr 2019, 11:04 pm | #26 | |
Assuming you have a valve based sig gen, connect your sig gen to the counter, whack the sig gens output on full and let everything warm up and stabilise for 1/2 hour, you can then set the generators dial to 455kHz IF or whatever needs to be per the indication on your counter. Then disconnect from the counter, wind the sig gen output down and start your sets alignment procedure. Is it a DAC90 you're trying to align? Andrew
20th Apr 2019, 2:07 am | #27 |
Ah yes thanks for that. It is a dac90a yes. I am going to check over everything again as suggested then follow the service data sheet procedure for alignment and see how I get on from there.
Mike |
20th Apr 2019, 6:51 am | #28 |
Unless the alignment has been twiddled, I've never had to realign a DAC90A....and I've done a fair few of them over the years.
21st Apr 2019, 8:49 am | #29 |
All 4 cores on the if transformers are wound right out which just makes me a bit suspicious and seems to warrant a look and check.
Mike |
21st Apr 2019, 10:15 am | #30 |
I've not seen any old signal generator for Radio Workshop use that can drive an ordinary bench frequency meter reliably.
On one generator I added a BNC via a 1kV 1nF ceramic capacitor and 1 K to the main osc output where anode feeds the attenuator. This pulls the frequency and adds a little distortion. So on the next valve generator I got I added this https://www.radiomuseum.org/forum/simple_rf_buffer.html In this case put a 50 Ohm terminator on when counter isn't connected to reduce leakage and avoid changing load, though the FET isolates pretty well. The J310 is easier to get, cheaper and maybe superior to the 2N3819 common in old articles. Powered off the heater supply. Either mount at input to attenuator or on the back of the added BNC. It's also a useful circuit to drive a scope or a pair of 1N60 germanium diodes in a peak detector for a DVM or wobbulator input, just to sniff a radio. Note that connecting direct with a scope probe will pull a radio IF or L.O., you need a short wire and even a series resistor on this buffer to avoid "pulling". Cable capacitance or gate capacitance is the problem. Only 10:1 probes switched to x10 at the clip end lightly load an IF or LO. |
21st Apr 2019, 10:26 am | #31 |
Actually the Advance
https://www.radiomuseum.org/r/advanc...erator_e1.html does have a high level output. However it was on a Car aerial type socket and not buffered. A 50 Ohm counter pulled the frequency and caused distortion. This is also good: https://www.radiomuseum.org/r/taylor..._generato.html I added a BNC as described above, but it needs the FET buffer. Despite being made maybe 1946, the alignment was still good. It needed lots of caps replaced. The Modulation transformer died but was replaced with a small 110-0,110-0 = 220V & 9V transformer suitably wired. One primary is audio amp load and the other in series with Oscillator. The secondary is audio frequency feedback for the 800Hz modulation. |
