Old 7th Aug 2019, 11:38 am   #1
AlanG4MOM
Default UK Suppliers of hookup wire
Hello,
I am about to undertake the rewiring of an R1155.
Can anyone recommend a UK supplier of suitable wire ?
Thanks
Alan
G4MOM
AlanG4MOM is offline
Old 7th Aug 2019, 11:57 am   #2
MrBungle
MrBungle's Avatar
Default Re: UK Suppliers of hookup wire
Bitsbox do some "reasonable" quality stuff sold in short lengths if you don't want to buy rolls and rolls of them: https://www.bitsbox.co.uk/index.php?...&cPath=200_203 ... good to 3A/1KV.
They do 7/0.2 stuff as well but it's horrid. Always go for Alpha Wire stuff from RS for that or anything esoteric like teflon coated or more amps
MrBungle is offline
Old 7th Aug 2019, 1:52 pm   #3
Tygon insulated aviation stuff is rather nice and doesn't melt while soldering, and strips quite well. Farnell and RS stock some.
Radio Wrangler is online now
Old 7th Aug 2019, 2:45 pm   #4
M0FYA Andy
Use the silicone rubber insulated wire available from a member of this forum. Unfortunately I can't remember his forum ID.
Andy
M0FYA Andy is offline
Old 7th Aug 2019, 3:06 pm   #5
David G4EBT
David G4EBT's Avatar
Andy
It's Phil Marrison - 'SWB 18'. He visits the forum most days, so is contactable via PM. Phil sells stranded silicone rubber insulated wire in two gauges and a wide range of vintage colours. Excellent stuff which is heatproof, strips easily and looks much more in keeping on vintage equipment than do gaudy PVC wires, which aren't heatproof and look out of place.
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is online now
Old 8th Aug 2019, 9:57 am   #6
lesmw0sec
I have a rather nice magnetic detector from a WW2 influence mine. Apart from the thing being excellently made like a Swiss watch, what is also impressive is the high quality wire used, being coated with some tough semi-transparent plastic (not PVC) which is in as good a condition as when made. I'd be interested to know what it is.
lesmw0sec is online now
Old 8th Aug 2019, 12:45 pm   #7
Polythene was used as insulation in some military-stuff during WWII and shortly after - the R4187 receiver [made by STC for use in V-bombers etc] used it too - all the wiring was in semi-clear-jacketed wire with coloured/numbered sleeves to identify the ends.
Old 8th Aug 2019, 1:15 pm   #8
kalee20
Andy
I second that!
kalee20 is offline
Old 8th Aug 2019, 4:15 pm   #9
turretslug
turretslug's Avatar
At risk of being thought facetious, UK suppliers of hookup wire include Hotpoint, Hoover etc..... Old washing machines often have a gratifyingly generous amount of mains-rated PVC wiring of ample gauge for HT and most heater applications in a spread of colours. If stranded PVC-insulated wire was deemed good enough for post-war Ministry overhaul of AR88s, use in R1155s doesn't seem too outrageous. The usual suspects (Farnell, RS etc.) do 16/0.2 stranded PVC insulated wire (my go-to vintage overhaul choice, good for most applications away from the more arduous temperature/current situations) rated at 1kV DC- this also often turns up at rallies in bargain slightly used reels, often in "prototyping pink"!
I'd be interested to know, too- I suspect it may be early HDPE (higher melting point), I believe that polythene was originally "discovered" by industrial chemists in the mid-thirties by the fortuitous polymerisation of ethane and its insulation properties were quickly appreciated. There's also a similar era vintage wire with relatively hard white plastic insulation that might also be a variation on the HDPE theme- I'm fairly certain that it's not PVC or PTFE. I gather that PTFE was another mid-thirties product but, although having excellent insulating and low-loss dielectric properties, was rather more challenging and expensive to apply practically and was probably largely a post-war thing.
turretslug is offline
Old 8th Aug 2019, 4:32 pm   #10
ex 2 Base
Washing machine have a lot of stranded wire of different colour. The more elderly ones have an interesting control board from which one can obtain resistors, diodes and a thyristor and they can also be reused. Phil's wire is also very flexible and heat resistant.
ex 2 Base is offline
Old 8th Aug 2019, 5:45 pm   #11
Originally Posted by turretslug View Post
At risk of being thought facetious, UK suppliers of hookup wire include Hotpoint, Hoover etc..... Old washing machines often have a gratifyingly generous amount of mains-rated PVC wiring of ample gauge for HT and most heater applications in a spread of colours. .
True: and cookers too; before sending my old cooker to the tip I recovered a nice bunch of different-coloured glass-fibre-insulated [so high-temperature!] wiring from it. The insulation is braided so passably resembles the old-fashioned cotton-braided wire used in days-gone-by.
Old 8th Aug 2019, 5:49 pm   #12
kalee20
Down side of using wire salvaged from washing machines etc is that it is probably PVC.
The accidental touch of a hot soldering iron will be extremely unsightly. Washing machine wiring is usually done with crimp connections, so no hot irons are used - but that's not the case for the R1155 rebuild.
Old rubber-covered wire is much more resistant. Silicone rubber even more so. If the R1155 was being made today, no doubt Raychem Type 44 wire would be used, or zero-halogen equivalent, as this is super hook-up wire.
To look 'right' and be easy to use, silicone rubber is the stuff to go for. And it does not age like the traditional rubber either.
kalee20 is offline
Old 8th Aug 2019, 6:58 pm   #13
MrBungle
MrBungle's Avatar
You can avoid that. Hold the end of the stripped portion with some fine hemostats as a heat sink and then solder the joint. Perfect every time.
MrBungle is offline
Old 8th Aug 2019, 7:14 pm   #14
Yes - alternatively do as I generally do and pop a pink Hellermann sleeve on the wire before soldering, then slide it over the soldered joint/tag when it's cooled. This works really nicely on things like toggle-switches and plug/socket tags. It may not be 'original' but it's just the sort of thing that would have been done by REME or RAF workshops in the 1950s if they were refurbishing a radio.
Old 8th Aug 2019, 9:45 pm   #15
turretslug
turretslug's Avatar
I do a similar thing with small stainless steel alligator bows, clipped longitudinally and loaded with slivers of aluminium foil. Sounds painstaking but done in a trice compared with the rest of the job and pretty much vital with early PVC wiring which seems to be very prone indeed to shrinkback/burning, the Pye CAT here which has neat, tight, single-strand PVC-coated looming with zilch slack being a case in point. Works really well in situations that could otherwise get ugly very quickly.
The R1155 was originated in the era of "waste not, want not, we're alone with our backs to the wall...." I can't help feeling that the use of salvaged but good-quality wiring from the likes of washing machines fits with the original spirit!
Old 8th Aug 2019, 9:54 pm   #16
M0FYA Andy
I honestly cannot see any reason to use second-hand recovered PVC insulated wire rather than silicone rubber insulated wire unless the cost is totally over-riding.
Hellermann sleeves over the wire terminations is certainly an improvement, but not authentic in an R1155.
Andy
Old 8th Aug 2019, 11:23 pm   #17
Jon_G4MDC
Jon_G4MDC's Avatar
I once put Hellerman sleeves on the soldered joints between some earth cables and their tags bolted to 1" copper earth tape at a Home Office, D-Tels, site.
It looked really good - to my young eye.
The site inspector said " Take them all off! ". "How will we ever know if we have a joint which is developing corrosion?"
I took them off.
Jon_G4MDC is offline
Old 9th Aug 2019, 8:38 am   #18
McMurdo
McMurdo's Avatar
Rapid Electronics do fairly small reels of hook up flex that come in various colours , it's plastic but doesn't shrink back when soldered like the old fashioned 50's pvc wiring, I used it on a 30's radio a couple of years back. I think it's sold as a cheaper alternative to silicone test lead wire. It's not as 'limp' as silicone or rubber.
https://www.rapidonline.com/rapid-gw...ck-25m-01-0605
Kevin
McMurdo is offline
Old 9th Aug 2019, 11:10 am   #19
MrBungle
MrBungle's Avatar
that's pretty cheap. Might grab a roll of that! Thanks for the heads up.
MrBungle is offline
