25th Aug 2018, 9:10 pm | #41 |
Re: Mercury Arc Rectifier. Value?
I've heard of these before, a bit risky if the plastic case is broken.
25th Aug 2018, 10:59 pm | #42 |
Metallic Mercury being the least toxic form, there is however for the information of all, an interesting paper (from the year 1926) by Alfred Stock, loosely translated as 'The Dangerousness of Mercury Vapor.' It concerns the experiences of persons working with Hg in an everyday role, but the symptoms are worthy of note due to their insidious/ambiguous nature.
I am very conscious of the risk/s and this thread has included musings i hadn't considered before. Did i potentially invalidate my car insurance by transporting a MAR? Possibly. Would a collision which ruptured the MAR have crushed me beyond caring about the environmental discharge? Again, possibly. By way of perspective I recall the M25 Hydrogen Peroxide incident from some years ago. 90% pure, and one of the canisters leaked onto the wooden bed of the lorry. Anyone who dismisses oxidising agents as less dangerous than explosives should have been there. Things got airborne! When the underwriters from Royal Sun heard it was 90% pure they...erm....re-wrote the policy. Dave |
25th Aug 2018, 11:15 pm | #43 |
I can remember a bloke that filled a 13 amp socket with mercury.
After it went bang his hand was silver. |
25th Aug 2018, 11:53 pm | #44 |
Lucien's mention of cabinet contamination makes me wonder how often they failed (as in envelope rupture) during use. The very idea of a large glass bulb with sticky-out limbs and what was effectively a conformal dead-blow hammer inside seems like asking for trouble! Could they have failed at bulb-to-limb joints through excess heating or uneven cooling, or been more vulnerable to later failure as a result of unsympathetic handling at installation? Also, bigger ones would have had a lot of current passing through the limb glass-to-metal seals, so connections must have been dependably good to avoid hot-spots. All-in-all, they seemed to have been something of a masterpiece of glassware, but not without a lot of caveats.
25th Aug 2018, 11:53 pm | #45 |
The Isle of Man railway uses mercury rectifiers...
https://youtu.be/yjMZ5qtyCUc |
25th Aug 2018, 11:54 pm | #46 |
No Longer a Member
All the talk of mercury reminds me of a story involving it.
Some years ago one of my daughters was given a science project, the topic being to investigate an old fashioned material that got replaced with a modern one and to compare and contrast the materials. Many students did plastic vs glass or wood and vinyl vs leather but two students did amalgam fillings vs modern composite materials. One was my daughter (the other classmate was the daughter of a dentist!). In any case when the assignment was done (supported by much google searching as this is how homwork seems to be done) my daughter showed me the assignment. Everything you could think of about the two materials, hardness, wear properties, thermal conductivity etc etc was covered and it was very well presented. But then I thought of electrical conductivity (and the composite material an electrical insulator) and demonstrated it with the meter probes on a somewhat large amalgam filling in one of my lower molars. Suitably impressed with the beep from the Fluke digital meter she added it to the list and blow me down got the prize for the best assignment. |
26th Aug 2018, 12:12 am | #47 | |
http://isleofman.com/News/details/56...splay-tomorrow http://www.britishtramsonline.co.uk/news/?p=4705 http://www.britishtramsonline.co.uk/news/?p=4909 David |
26th Aug 2018, 12:34 am | #48 |
I never knew it had been unplugged. It was a big blue sparkly thing that you could read the paper by...
They used to have them on the southern railway. there is still a building at Chislehurst junction where they were installed. A big thing with large windows. |
26th Aug 2018, 12:43 am | #49 | |
More information on the early years of the Crich tramway including the power supplies used can be found in the three part blog linked below (picture of the ex-Walsall transformer rectifiers in part three) http://tramways.blogspot.com/p/crich-1959-1969.html David |
26th Aug 2018, 3:27 am | #50 | ||
I also saw a nice demonstration in which someone filled a mould with mercury, held a wooden handle upright in the middle of the mould, poured liquid nitrogen over the mould to freeze the mercury solid; then withdrew from the mould a hammer with a head of solid mercury, which they used to knock several large nails into a piece of wood. It really brought home how mercury is just a metal, albeit one with a very low melting point, but still a metal like any other metal. Molten solder behaves similarly to mercury while it is still liquid; and there are (or at least, there used to be; they may have contained one or more ingredient considered too dangerous today) special, low-melting point metal alloys which can be melted in the hand, or by breathing on them.
26th Aug 2018, 4:45 am | #51 |
No Longer a Member
I'm saving a jar of mercury I have to make a Faraday motor. The one where the edge of the slowly rotating copper disc spins in a pool of it. The current passes from the axle to the edge and a big U magnet's field crosses the disc.
26th Aug 2018, 8:20 am | #52 |
I too have one of those puzzles and a few tilt switches and mercury-wetted relays, a couple of Hg thermometers and possibly a sphymomanometer at the back of a cupboard too.
As previously mentioned, there must be a lot of mercury tucked away in private hands. |
26th Aug 2018, 9:28 am | #53 | |
At the time (early 60s) I had a jam-jar full of mercury recovered from some relays which were due to be scrapped where my father worked. It was later sold to the local scrap-merchant for £65! Andy |
26th Aug 2018, 9:28 am | #54 |
A long time age ,when my children were in junior school, the discussed subject was electricity. I made a replica of the Farady motor to demonstrate magnetism etc. Not having mercury to hand I improvised with a salt solution. This actually worked and the rod rotated in the bath of saline.
Malcolm |
26th Aug 2018, 10:59 am | #55 | |
26th Aug 2018, 12:28 pm | #56 |
A valid point and i can't argue..but i can imagine with the blend of plastics in modern construction a vehicle fire is something they would already treat with great respect as regards the black smoke, and also alloy cylinder heads which have been known to explode. (Several horror stories circulate regarding the combustion products of certain synthetic rubbers, ie hydroflouric acid, which eat flesh and according to Haynes manuals 'may ultimately involve amputation of the limb concerned') On the rare occasions i see a category A burn-out in the middle of nowhere i think of this and 'phone it in asap.
There is another trick which can be done with amalgam fillings which is definitely not recommended- i once ate a kit-kat with a fragment of aluminium foil on it, and received a direct electric shock in the nerve. Dave |
26th Aug 2018, 12:38 pm | #57 | |
The consensus would appear to be that far from having a value, it is a liability. Your friend would be best advised to seek professional help, to avoid serious, possibly legal, difficulties in the future. This is one official publication, there are probably others! https://www.gov.uk/government/public...ive-precursors |
