Old 22nd Sep 2008, 9:14 pm   #1
murphyv310
murphyv310's Avatar
Default 4 Valve amp
Hi.
For quite a while I have thought about making valve amps while I have been off ill.
Years ago I built some amps for friends using EF86, ECC83 & two 6L6 with a GZ30 rectifier. I know that at least two amps are still in use with no faults in at least fifteen years.
Iv'e set about building a different amp using a 6BA6, 6SN7 & 2 of 6V6GT. Instead of a valve HT rectifier I am using 2 IN5408 rectifiers and smoothing rated at 450v. All components are modern except the Transformers which are Gardiners NOS. The amp is loosely based on the Brimar VA10 design.
The performance is stunning and is running 6 watts RMS with less than 1% distortion.
here are some pictures, note the temporary position of the volume control as I need some aluminimum to finish the front panel.
Trevor
ID:	20080   Click image for larger version
ID:	20081   Click image for larger version
ID:	20082   Click image for larger version
ID:	20083   Click image for larger version
Cheers,
Trevor.
MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member
murphyv310 is offline
Old 22nd Sep 2008, 9:15 pm   #2
murphyv310
murphyv310's Avatar
Default Re: 4 Valve amp
And the last five
Trev
ID:	20085   Click image for larger version
ID:	20086   Click image for larger version
ID:	20087   Click image for larger version
ID:	20088   Click image for larger version
Cheers,
Trevor.
Old 23rd Sep 2008, 9:42 am   #3
Neil F
Neil F's Avatar
Lovely tidy work, Trevor If it sounds half as good as it looks it'll have been well worth the time it must have taken. Are you going to build it a sister so you can do stereo?
Neil F is offline
Old 23rd Sep 2008, 2:27 pm   #4
murphyv310
murphyv310's Avatar
Hi Neil.
I think I will build a stereo version, but I now need to look out for a pair of o/p transformers and some more octal bases.
The chassis I used was from an old crystal calibrator, but my local engineering shop is making up some chassis for me, iv'e got some step drills which are great for the bigger holes.
This amp was built in a weekend so they dont take too long.
Trevor
Cheers,
Trevor.
Old 23rd Sep 2008, 2:46 pm   #5
Tim
Tim's Avatar
Excellent work.
I'm not worthy, I'm not worthy...............
Tim is offline
Old 25th Sep 2008, 11:49 am   #6
dominicbeesley
dominicbeesley's Avatar
Lovely job!
Any chance of a circuit diagram?
Dom
dominicbeesley is online now
Old 25th Sep 2008, 8:13 pm   #7
mark pirate
mark pirate's Avatar
Thumbs up Re: 4 Valve amp
Lovely job Trevor, i love how neatly you have wired it
I look forward to seeing a stereo version!
Keep up the good work
Mark
mark pirate is offline
Old 26th Sep 2008, 8:38 am   #8
Mike Phelan
Mike Phelan's Avatar
What a great job, Trevor! The underchassis layout is as good as a Quad.
Is there a preamp on the way?
Mike.
Mike Phelan is offline
Old 26th Sep 2008, 9:34 pm   #9
Phil G4SPZ
Phil G4SPZ's Avatar
Pity I didn't see that when I visited, Trevor! That amp looks a really neat professional job. Who needs stereo anyway?
PM sent about the records, too. Cheers,
Phil
Phil
Phil G4SPZ is offline
