6th Feb 2006, 8:45 am | #1 |
Cream DAC90A - Mains Dropper Cabinet Crack.
Hi guys,
ok I am not the worlds best, not even the worlds okist cab restorer but is there any way to make the heat crack on the top of a cream DAC90A to look less obvious? Regards Andi
33, 45, 78, around and around they go...
6th Feb 2006, 6:07 pm | #2 |
Re: Cream DAC90A - Mains Dropper Cabinet Crack.
Leave it as it is Andi. The heat crack on an ivory DAC90a is quite normal and is a feature of this particular model. Only those that have been rarely used may escape this problem. It really wont devalue it at all. I have only ever seen one ivory DAC90a without the heat crack and that was unused in its original box .
Neil |
6th Feb 2006, 9:48 pm | #3 |
Ok, Thats great news as aside from that its in very very nice condition, just needing a replacement mains dropper as the largest section is open :-(
it has been partially recapped from the looks of it and its very clean. Regards Andi
6th Feb 2006, 10:34 pm | #4 | |
Yes, there is no way to hide the crack in these radios, the heat from the dropper makes the crack sooty from the inside out
David |
6th Feb 2006, 11:20 pm | #5 |
Erm... How do I do that then?
Andi PS Doing a search as I post this...
6th Feb 2006, 11:23 pm | #6 |
Administrator
You can start here http://www.vintage-radio.com/repair-...per-calcs.html then look at "one I prepared earlier" here http://www.vintage-radio.com/recent-...ekco-u245.html
6th Feb 2006, 11:55 pm | #7 |
Thanks for that Paul.
Will look at this a little more closely and see if I can find a scrap DAC10 first as I know it had the same dropper... Regards Andi
