11th Dec 2010, 11:41 am | #1 |
RACAL RA-17: taking out the first VFO?
Hello,
I own a RA-17 which was previously used in the Dutch army. This receiver has been suffering from a bad working first VFO. When I turn the megacycles knob, there are a lot of cracking noises from the speaker and it is hard to tune to a new band. It seems as though there is a bad contact somewhere. So now I would like to take the first VFO out. I have remove three knobs from the front panel: the large megacycles knob, the antenna tune and range knobs. Als removed 2 10 cm long screws from the top of the VFO. So now I can move the chassis with the VFO freely, but it seems to be stuck somewhere. Is there anyone who can tell me how to take the VFO out? Thanks, Joop |
11th Dec 2010, 4:28 pm | #2 |
Re: RACAL RA-17: taking out the first VFO?
Joop - hi,
I have only done this on a RA117E but the chassis design is similar to the RA17. Others who may read this may have alternative methods, but this is the easiest although time-consuming: 1 Remove all knobs, then remove the front panel. This is necessary to get exposure to the mechanical bits such as the film-strip lock and the 2nd VFO chain for cleaning / lubrication, then, 2 Unplug and remove the 100kHz calibrator from the 2nd VFO – easy, just a knurled knob and a BNC connector. 3 Lock the VFO from the front panel-locking spigot. This moves some of the metalwork away from the 2nd VFO. 4 Remove the 2nd VFO. There are some bolts on the top of the chassis and one underneath. You will need to unsolder the heater and HT leads underneath located on a black tag strip. You will also need to unsolder the blue wire (on a RA117E) that connects to the Harmonic Mixer board at R18/L20, and the Orange and red wires that connect to the 40MHz band pass filter. 5 Now you have sight of the uncluttered 1st VFO. 6 Undo the bolts on the top; unsolder the HT, Heater and AGC screened cable from the bottom tag strip. 7 Unsolder the RF input co-ax from the attenuator. 8 Gently remove the first oscillator feeding the RF input co-ax through the chassis grommet. 9 Rebuilding is the reverse of the above. 10 Use some silicone grease to lubricate the grommet for the RF input co-axas it will be easier to pull through on re-installation. It sounds daunting but its worth it. I use some screened microphone cable to connect the tag strip to the 1st VFO so it can be powered on the bench to fault-finding. As you have gone to this trouble, its worth checking that the front-end gain is correct by injecting a known value into the front-end co-ax and measuring the output on Test Point 2 at the output of the 0-30MHz BPF. Above all else, good luck with your project! Regards, Nick |
11th Dec 2010, 6:32 pm | #3 |
Glad Nick could help. I've work on a million of these and can't remember at all. Senile dementia?
Bob W
Radio Tircoed - Working for the Community |
12th Dec 2010, 7:11 pm | #4 |
Hello Nick,
thanks a lot! I will have a go at it later this week and let you know my results. Regards, Joop |
14th Dec 2010, 5:45 pm | #5 |
If you remove the round "megacycles" white dial , and the RH side panel it is possible
to get the first vfo/mixer chassis out without disturbing the Kc/s VFO. I usually replace the "Aerial" input cable with min ptfe coax. Whilst you are in there replace the two grid bias 100k ht to gnd resistors. G3TSA |
17th Dec 2010, 10:36 am | #6 |
I have had this problem on mine & I think it is poor earth connection to the spindle of the tuning capacitor, probably dirty wiping leaf spring contact, I cured it without dismantling by getting loads of switch cleaner round the tuning capacitor shaft at the front and working it back & forth to clean the contact. Its worth a try to save having to dismantle
27th Dec 2010, 9:19 am | #7 |
Thanks saxmaniac, sounds like it will be an easy repair
Still have to take the VFO out, Christmas holiday has been busy Will keep you informed |
29th Dec 2010, 1:26 pm | #8 |
It worked!
I wanted to have a look at the capacitor anayway, so I decided to dismantle. Took all the knobs off, then the side panel. Removing the white scale helps a lot, there will be more room when you do this (be sure to mark the position of the scale). After desoldering a couple of wires, I could take the VFO out sideways. Will replace the coaxial cable, a thinner cable will have more room inside the switch cabinet. Thanks to all that helped |
30th Dec 2010, 3:13 pm | #9 |
IMPORTANT- switch cleaner can make nylon grow bigger!
The bandswitch rotor is nylon. You will not notice for a while ,however the slightly stiff rotation will cause the centre hole to become bigger.Then you will discover you have to turn the switch a little too far , then back. The only solution then is to replace the whole switch. (This also happens to the gears in the Drake T4/R4) Over the years I have seen this in about 1 in ten sets. When you have the unit out , replace the two 100k resistors r32/r32a. They are often high.(HT to ground ECC189 bias) There is no need to replace any others unless they are more than 20% high. |
