10th Nov 2010, 11:17 pm | #1 |
Wireless Operator's duties in pathfinders?
I'm researching my late fathers time with 35 squadron based at RAF Graveley I am trying to find out what his typical duties would have been, especially as radio silence was all important.
There would have been a separate signals briefing. What frequencies were used to remain in contact with their control and was this at their base or one of the more central stations? If acting as Master Bomber would they use the same tx/rx 1154/1155 sets for contacting others on the same mission? or was there a VHF set? Is there a book or website that goes into such detail? I realise it’s a wide-open query but would appreciate anything that goes towards my understanding of what he did. My thanks in advance |
26th Nov 2010, 5:27 pm | #2 |
Re: w/op duties in pathfinders
Hi Paul,
You don't say how far you have got with your research but you may be able to get a copy of your fathers service record from the Air Historical Branch. I think it would be free if your mother applied for it but if that's not an option, then for you there is a charge. This would then pin down some dates from which you can find out what aircraft were used on 35Sqn at RAF Graveley. There is lots to read by Googling 35Sqn or RAF Gravely. Hope this helps. Regards, Alf |
26th Nov 2010, 6:49 pm | #3 |
Re: Wireless Operator's duties in pathfinders?
Hi Paul,
You may well have the following info but here goes any way; 35 Sqn (Madras Presidency) 8 Group PFF Force (Pathfinder) Squadron code `TL` Flew Halifaxes from 1940 to 1944. Lancasters from 1944 to 1949. The T1154 transmitter covers frequencies of 2.35 Mc/s to 16.7 Mc/s (HF ranges) and 200Kc/s to 500 Kc/s (MF range). Any individual frequencies within these ranges could be used as required for long range CW (morse) communications back to Bomber Command HQ. By 1944 a VHF set Type TR1143 (100Mc/s to 124Mc/s) would most likely have been installed as well for close range up to 125 miles. ie enroute/sortie. All subject to radio silence directives of course. Hope this helps, John. |
27th Nov 2010, 1:09 pm | #4 |
I have seen small round black die-cast boxes with an inbuilt switch and morse key. I think the switch selected either a port or starboard light so that aircraft could communicate with each other in silence. Good old Morse and no doubt it was one of the required skills of the wireless operator.
27th Nov 2010, 6:32 pm | #5 |
As TC says that is correct,believe i have one of these in my collection.Seen odd ones on ebay.
David GM8JET |
29th Nov 2010, 3:37 pm | #6 |
I believe that the wireless operator also monitored the fishpond display. This sat to the LHS of the R1155 and was connected to the H2S. It basically gave a downwards view of the air below you so that you could see what aircraft were moving around. An attempt to see night fighters sneaking in below you.
Robin |
3rd Dec 2010, 10:45 pm | #7 |
According to AIX the 1944 RT callsign for RAF Graveley was BRISHBRUSH, which may have been used on the approach and tower freqs, and possibly on VHF by that time. Certainly a callsign your relative would have known well !
Some further info HERE and HERE It would be interesting to know where the operational messages were sent to and received at, whether it was the Sqn's base or to a higher level organisation. |
3rd Dec 2010, 11:00 pm | #8 |
That first link just leads to a log-on page for me.
3rd Dec 2010, 11:20 pm | #9 |
