31st May 2017, 12:10 am | #1 |
Akai x-5000w Reel To Reel No Bass
Okay, here goes, 2 years on and I still can't seem to figure out what's wrong.
I have my X-5000W of 2 years and I have been using it. It has had a full mechanical service but the electrics are just too much to deal with, opening the board and untying the wires is basically too much work. So, the problem is that the left channel has a really low, low end. It's so obvious that its runs off at about 200hz. No recording has anything lower than that, probably 150hz at the lowest. The right channel is perfect. I have attached a schematic which may help, but this is not only for recording, but when playing a tape recorded perfectly on another deck, I still don't get bass on the left channel. Recording a tape on this deck and playing it on a perfect deck, also has no low end on the left in the recording. This can either be in the Eq circuit or the Push-Pull record/amp section. Not sure where to check and if anyone can tell me where to check in the right channel, it would be appreciated. Recording Bias is not a problem as the deck has a cross field head system that has the same voltage applied to the right and left of the bias head. So the bias is the same in left and right and only turned off with the 3-2 and 1-4 switch. |
31st May 2017, 3:18 am | #2 |
Re: Akai x-5000w Reel To Reel No Bass
Sounds a bit like faulty capacitor(s). I'd try to isolate it. Is the loss of bass only when using the internal power amps, or is it also at the 5 pin DIN socket/line outs when feeding an external amplifier?
Tim |
31st May 2017, 7:50 am | #3 |
From the schematic, if I am not wrong, the same amp is used for rec and pb via the rec/pb switch. Probably some electrolytic caps have dried out. Check the caps in that amp first.
Regards, John |
8th Jun 2017, 3:52 pm | #4 |
Sorted - C106 in the left channel was down. Replaced the same in the right channel (C206) 6.3V 47uF. Thanks once again guys
