Old 18th Aug 2018, 11:07 am   #21
Default Re: Quick-and-dirty testgear: mains voltage monitor.
That'll be easy to do - following a job recently[1] I've got a batch of the small wire-ended fuses that are usually concelaed within the windings of 'wall-wart' transformers. Not sure what their rating is but it can't be more than an amp.
[1] Once postage was included it was not-really-that-much-more-expensive to buy 100 of the things than ten of them...
Old 18th Aug 2018, 3:13 pm   #22
broadgage
Before re-use of the fuses that you have, do confirm that they are in fact fuses that protect against overcurrent.
If intended to be concealed within the windings of a small transformer they may well be thermal fuses that open at a certain temperature.
Such thermal fuses WONT open on overcurrent unless so gross that the plug fuse or circuit MCB has probably operated first.
broadgage is offline   Reply With Quote
Old 18th Aug 2018, 4:41 pm   #23
Checking the spec for the things I bought, they're actually "polyswitches" so they deal with both excess current *and* excess-temperature events in one convenient package.
Old 20th Aug 2018, 7:07 am   #24
thermionic
thermionic's Avatar
Itís quite possible that your Polyswitches will be unsuitable for 230 Volts AC.
Most of these have maximum voltage ratings less than 100 Volts. I would not use these until I could confirm their spec.
SimonT.
The honesty of imperfection..........
thermionic is offline   Reply With Quote
Old 20th Aug 2018, 2:53 pm   #25
mhennessy
I must admit that the notion of burying a Polyswitch in the windings of a transformer is a new one on me. Is this actually done?
The only thermal fuses that I've seen embedded in transformer windings are the non-resettable types. On the face of it they seem like a bad idea, but every time I've met one that's gone open-circuit, it did so for good reason.
Littlefuse give data about derating for ambient temperature, but as their fundamental MO is self-heating, they don't appear to give any data about thermal resistance, which you'd need to know if you're hoping to conduct heat into them.
Ultimately, I can't work out if this is an incredibly smart bit of lateral thinking, or an awful bodge that is likely not supported by whoever makes the Polyswitch. Part of me wants to like it, but I feel that I'd need more information before I can make my mind up.
mhennessy is offline   Reply With Quote
Old 20th Aug 2018, 4:53 pm   #26
Refugee
Refugee's Avatar
If you place one against the core of a transformer it will go high at a lower current.
If it were in the windings it would to some extent monitor the temperature of them.
Refugee is offline   Reply With Quote
