Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Service Manuals, Circuit Diagrams and Data Sheets Wanted
Service Manuals, Circuit Diagrams and Data Sheets Wanted If you need help finding service data post a message here. Please do not request or offer data that is available from www.service-data.com
Reply
Old 27th Sep 2023, 5:39 pm   #21
Paul Stenning
Administrator
Paul Stenning's Avatar
Default Re: Philips EL3302A/15P Service Data
Excellent, thank you.
Paul Stenning
Forum Admin/Owner and BVWS Webmaster
Paul Stenning is online now   Reply With Quote
Old 27th Sep 2023, 6:57 pm   #22
Maarten
Originally Posted by dazzlevision View Post
I have unearthed one of my EL3302A/15P machines and there is a small, folded up circuit diagram tucked in between the case and motor housing. I can post it here if you'd like?
The WT03 code on the motor housing label shows it was made in Austria (Vienna) and the 247 indicates indicates it was made in mid-1967.
Indeed Austria, but likely in 1972 week 47 as they already changed the date format by 1967 (at least for cassette recorders).
I'm not 100% sure about the letters as they are indeed quite confusing and not use in this way on any other kind of equipment that I know of. I do agree it's most likely that the A immediately behind the type number stands for Austria. I've also noted down the B for Spain, D for Germany, G for the UK and the S for Singapore.
Maarten is offline   Reply With Quote
Old 27th Sep 2023, 8:31 pm   #23
dazzlevision
Ah yes, these Philips date codes can be a little ambiguous. Upon reflection, 1967 may be a little early for Lockfit transistors and the EL3302 model was produced well into the 1970s.
I have two EL3301 models that were made in the UK, with BA (Croydon) serial number labels. The model number on these labels is EL3301G/15. It says Made in England (or was it Britain?) in front of the meter.
dazzlevision is offline   Reply With Quote
Reply
