30th May 2020, 1:39 pm | #1 |
Ducretet Thomson L524
Hi I'm asking for a friend because he is not very computer minded would anyone have schematic or anything on Ducretet Thomson L524 I tried some French sites but still no luck
30th May 2020, 1:59 pm | #2 |
Re: Ducretet Thomson L524
Sorry not sure why this got moved as I'm only after information like is the L624 almost the same set or where to find out and I cant find anything
Last edited by rockinmark; 30th May 2020 at 2:04 pm. Reason: Because it was moved to wanted |
30th May 2020, 2:13 pm | #3 |
Here is a schematic that I got from radiomuseum. If you do an internet search and look at "Images of Ducretet Thomson L524 schematic" there are several similar schematics and a little other service info.
Last edited by AC/HL; 30th May 2020 at 4:02 pm. Reason: Copyright attachment removed |
30th May 2020, 3:17 pm | #4 |
Thanks for that DMcMahon do you know what type of capacitors are in there are french sets the same as British set where you have hunts and wax ones that need changing or do they use different styles. I have told him not to turn it on anymore because he said it starts ok but then goes quite.
30th May 2020, 3:55 pm | #5 |
No sorry I know nothing about any radio sets. I would guess that due to its age its coupling/de-coupling capacitors may be paper di-electric type.
David |
30th May 2020, 4:05 pm | #6 |
Please do not post any radiomuseum schematics. They can be downloaded directly by request if required.
30th May 2020, 4:09 pm | #7 |
OK understood.
David |
30th May 2020, 6:16 pm | #8 | |
You may find the extra confusion of capacitance values in "cm" This is a cgs unit for capacitance. 1cm = 1.113pF. For any except precision applications, 1cm = 1pF will be near enough.
31st May 2020, 1:05 pm | #9 |
Thanks for that chris I think he wants to get someone to fix it for him so I might ask on the forum for him I enjoy doing stuff for myself at my own risk of it not working but not somebody's stuff
Thanks everyone |
31st May 2020, 3:22 pm | #10 |
There's a non RM originated circuit I uploaded a while back in post #2 here:
https://vintage-radio.net/forum/showthread.php?t=70958
15th Jun 2020, 12:50 pm | #11 |
Capacitor type
What would I replace a 0.25nF axial capacitor with? Would I use a 0.22nF?
15th Jun 2020, 1:43 pm | #12 |
Re: Capacitor type
Yes.
15th Jun 2020, 1:57 pm | #13 |
Re: Capacitor type
Yes and of course make sure the replacement voltage rating is at least equal to the original.
15th Jun 2020, 3:34 pm | #14 |
Re: Capacitor type
Before changing anything, what type was the original, and what was it doing?
Changing to 0.22nF == 220pF might make no noticeable difference in audio circuitry, but in the tuned circuits of a radio, it could cause trouble. David
15th Jun 2020, 3:41 pm | #15 |
Re: Capacitor type
Not sure what they are just trying to get bits together voltages are very high its a French radio
15th Jun 2020, 4:57 pm | #16 |
I have managed to get this radio, he thought it would cost him too much to get fix so I did a swap. It has a lot of glass type capacitors that are falling apart they have high voltages on them 1500v/2500v. Would they have to be that high or would the yellow axial 650v type do?
Mark Last edited by AC/HL; 15th Jun 2020 at 5:54 pm. Reason: Threads merged |
16th Jun 2020, 12:50 am | #17 |
Looking at the voltages in the circuit I posted (figures in circles) and considering the low voltage valve lineup, apart from the capacitor from output anode to chassis which could usefully be a 1500V type and the RF filter cap from mains line to chassis which should be a class Y part there's no reason to use anything rated higher than 400V. So 630V would be more than adequate.
16th Jun 2020, 8:15 am | #18 |
Looking at the scismstic that Chris posted I can't see why the capacitors are 1500V. I didn't notice until I took the one out I could read. The sheet in post 15 is from a similar radio but are the same types that got for reference.
Mark |
16th Jun 2020, 8:48 am | #19 | |
Re: Capacitor type
In this case with the updates that some of the capacitors are rated at high voltages, it may not apply strictly, needs more checking why these particular capacitors are rated that high. |
16th Jun 2020, 8:52 am | #20 |
It was nothing unusual for sets to be fitted with capacitors which were too good for the job. ie lower voltage ones would have sufficed.
