22nd Jan 2021, 9:08 pm | #1 |
Melted mat
So the deck in this Marconiphone is a Garrard RC210 and the turntable mat has somehow melted into a solid mass, as hard as bitumen. Any suggestions for removing it please?
Knobs and tubes rule ok |
22nd Jan 2021, 9:18 pm | #2 |
Re: Melted mat
Warm it with a hot-air-gun?
Old rubber degrades in all sorts of odd ways. If heat doesn't soften it to the point where you can lift it off with a palette-knife or similar blunt-scraper, you may need to go chemical and deploy paint-stripper. |
22nd Jan 2021, 10:34 pm | #3 |
Re: Melted mat
theres a product called Rubber Renue its well stinky so advice doing it in open, you can brush it on let it dry off, but a turntable mat is large area so may be to costly to use it.
I bought a bottle of it on ebay cost about £10 i tried it on idler wheels etc and seems to work, i bought it to use on a old cartridge i was rebuilding as the rubber was solid and got so much stylus noise and skipping so thought id give it ago. Firstly i soaked the rubber bit over night ooops big mistake it was so soft and that was the end of that So i dipped it in some for 30 mins and it softend it up and worked great. I tried some other things which went wrong and stuck them in vasaline over night they soon hardened again, so even a disaster of to soft can be sorted. If turntable mat has gone light thru age bit of isopropal alcohol on cotton wool and gently rub around soon brings the orig colour back, i had a burgundy slip mat that i had washed it tried up like a old hot water bottle, i looked online and someone suggested the alcohol and it worked, its got a lovely colour back again |
23rd Jan 2021, 11:11 am | #4 |
Re: Melted mat
Put the whole turntable platter (remove the underside thrust washer if it's there) in hot, soapy water and after 5 mins ease it off with a paint scraper. Carefully dry the metal platter and grease the spline. You can make a temporary mat from a 10" polystyrene Pizza base and paint with emulsion to match if you wish.
Edward. |
24th Jan 2021, 1:48 pm | #5 |
Re: Melted mat
Low-grade junked/broken plastic Japanese turntables from the 90s often have quite reasonable platter mats that seem to be discarded along with the turntable.
I only realized this by accident when wandering past a few "kerbside clean-ups" about ten years back and at the time I happened to be in need of a new platter mat.....since then I've kept a watchful eye out for plastic turntables by the kerb/skipped/charity shops etc..... Bruce |
