26th Jan 2021, 1:36 pm | #21 | |||||
Re: HMV 1252 FM Tuner - front end problem
Thank you all so far for all the suggestions.
I remain totally stumped. I do wonder if part of the problem is the aerial and whether it needs a coil of some sort between the aerial feed and ground. I will attempt to rig up some form of dipole and run more tests. Seems a pretty standard VHF design of the time, but just zero performance! |
26th Jan 2021, 2:59 pm | #22 |
26th Jan 2021, 5:46 pm | #23 |
I would still try these valves in a known working RF stage in another VHF tuner that uses the same valve. The ECC85 is pri-marily an audio valve, so a high spec one will be needed for RF use. I had to go through 4 valves a few years back before I found one that worked at RF, yet they all worked perfectly OK at audio frequencies.
Dave |
26th Jan 2021, 5:59 pm | #24 | |
I have seen other conversations about ECC85 VHF stages and I am starting to think this set might just be poor quality. |
1st Feb 2021, 5:07 pm | #25 |
Still struggling with this set, and would welcome any more input.
So, latest tests. Still don't have another VHF set to test valves in, but have now tried 3 different ECC85's. I think the problem is the oscillator, despite all voltages being roughly correct. With the probe of my scope on x10 to avoid too much loading, I cannot detect an oscillator output anywhere, so I don't think it is running. All components test passively OK. I think the 'locally generated' test FM signal was a red herring as probably only bleed on the harmonics through to the IF stage. Can anyone help with how this thing is supposed to oscillate? I think the first RF amp stage is probably working. |
1st Feb 2021, 5:48 pm | #26 | |
Lawrence. |
1st Feb 2021, 6:41 pm | #27 |
Thank you Lawrence for such an excellent description. Very helpful.
On that basis I think L5/L6 is the primary problem. The original former was broken and the ferrite slug was wrecked. As it was only 3 turns each, I re-wound them onto a new former with new slugs, but clearly the spacing of the windings is not correct so the oscillator is defunct. I will have to play around with the coil and see if I can get it to oscillate. |
1st Feb 2021, 6:55 pm | #28 |
Make sure the new slugs are VHF friendly, some aren't.
Lawrence. |
1st Feb 2021, 6:58 pm | #29 |
1st Feb 2021, 7:05 pm | #30 |
It's to do with the composition so far as I know, in the old days ferrite wasn't much cop above 2MHz.
Lawrence. |
1st Feb 2021, 7:10 pm | #31 |
I didn't know that! Oh - I don't think there will be any way to tell! All I know is that I got them from some old coils in an AM radio, so maybe not. Yet another fun problem to add to the mix!
1st Feb 2021, 7:24 pm | #32 |
Also the connections of the windings matters too, eg: if L5 connections were swopped round or L6 connections were swopped round then the feedback would be -ve and not +ve, that also means it wouldn't oscillate.
Lawrence. |
4th Feb 2021, 4:44 pm | #33 |
What a dope! While working on this set yesterday, I realized that I cannot check if the set is oscillating with my scope anyway, as it is only 20MHz.
Still think the fault is around the coils. Back to the drawing board! |
4th Feb 2021, 4:56 pm | #34 |
If the oscillators working you should be able to measure some grid current or 'scope a signal at the input to V2.
Lawrence. |
4th Feb 2021, 4:58 pm | #35 |
There is something, but not sure if it is correct at the moment. My gut feeling is the oscillator is probably working but way off frequency due to L5/L6 being previously damaged.
