25th Jan 2021, 11:05 pm | #101 | ||
Re: Dansette conquest turntable motor help
Thanks very much lawrence, I will change those tomorrow |
25th Jan 2021, 11:11 pm | #102 | |
I will check see if there is anything suspect there Thanks for your help |
26th Jan 2021, 10:47 am | #103 | |
Lawrence. |
26th Jan 2021, 11:38 am | #104 |
Going to take a look later but you have all been a great help the fog is lifting
26th Jan 2021, 3:22 pm | #105 |
Success I now have a great tone no distortion at all, plenty of volume which is fantastic, thanks Lawrence for your patience
The hum has returned though which increases with volume I have re checked the dc voltages on pin 6 and 7 6- 175 volts dc 7- 90 volts dc Could this point to another fault |
26th Jan 2021, 3:57 pm | #106 |
Measure the AC voltage at the anode of the rectifier (the rectifier tag that's connected to the mains transformer)
And measure the DC voltage at the cathode of the rectifier (the rectifier tag that's connected to the circuit board) Lawrence. |
26th Jan 2021, 5:11 pm | #107 | |
I have fitted the amp into the record player cabinet and put the turntable back on and the hum is hardly noticeable I’m happy with how it sounds now thanks very much for your assistance on this Regards Andy |
26th Jan 2021, 5:18 pm | #108 |
No problem.
The reason I asked about the rectifier voltages is that sometimes the conduction resistance of selenium rectifiers can increase with age. Lawrence. |
26th Jan 2021, 8:55 pm | #109 |
I see so I may need to check anyway, I will test when I strip the player down again, you wouldn’t believe it but the turntable is acting up again now, auto problems, it was working like a dream before, now dropping 2 records down together, tomorrow is another day
27th Jan 2021, 10:13 am | #110 |
Does anyone have an exploded diagram of the bsr monarch ua 12 fitted to this record player
I am unable to find anything on the web. Last edited by Cobaltblue; 27th Jan 2021 at 10:56 am. Reason: typo |
27th Jan 2021, 11:15 am | #111 |
27th Jan 2021, 5:25 pm | #112 |
Thanks Graham
I have downloaded the file |
28th Jan 2021, 3:57 pm | #113 |
Two records dropping together on a BSR is usually caused by the moving part in the top of the stacking spindle sticking. This is another of those places that rely on dry metal-to-metal contact.
28th Jan 2021, 6:01 pm | #114 |
Hi Julie
I have removed that part, it appears free and easy to move, it was a bit tricky putting back together but I think I have done it. I have tried again and still the same. The BSR download although pretty good has not really made it clear enough Last night I was tinkering and on a couple of occasions when selecting auto with 2 records stacked, the player placed the needle on the record only to lift again return to rest and reject itself But the main problem is not playing on auto at all I have attached a couple of images not sure what this spring is actually doing ? The straight part is it supposed to go behind anything The diagram is not clear |
28th Jan 2021, 6:57 pm | #115 |
Is the overarm correctly located and pushed down firmly on the stack or have we been here before?
Edward. |
28th Jan 2021, 8:24 pm | #116 | |
Lawrence. |
28th Jan 2021, 8:55 pm | #117 |
Cheers Lawrence and Edward, so I think I have got somewhere when I bend the arm very slightly, the auto works absolutely fine on a single record, but if I place 2 records it still drops both
The arm drops as it should Edward, but there appears to be a removable rubber underneath the arm which is well past it’s best I think this is the issue can one be purchased |
28th Jan 2021, 10:13 pm | #118 |
Yes Edward it’s now ok on one record, I think the problem could be due to some over zealous pulling up of the overarm, it now played 1 record perfectly well, the only problem is that it still drops 2 if 2 are on the spindle, but there is a piece of spring steel underneath the spindle this appears to have some movement under the bottom of the spindle, could this be worn and not have the force it should have ?
