Old 27th Oct 2007, 9:57 am   #1
unitelex
Default Bush VHF61 distortion at lowest volume setting
My VHF61 gets a clear undistorted audio for BBC stations (reasonable modulation levels !) except when the volume control is at or close to the minimum setting.
Suspect it is something to do with the AGC?
Any clues ?
unitelex is offline
Old 27th Oct 2007, 11:14 am   #2
PJL
Default Re: Bush VHF61 distortion at lowest volume setting
Have you replaced all the capacitors including the little hunts ones?
If so, try it on an external speaker first....Peter
PJL is offline
Old 27th Oct 2007, 3:17 pm   #3
unitelex
Hi PJL, yes, should have mentioned, all paper/mettalised paper caps have been replaced.
Also replaced the EL84 output pentode and the EABC80. The new EL84 made some improvement, but the distortion is still there.
Good suggestion about the speaker, just tried and external on, but alas, same distortion...
unitelex is offline
Old 27th Oct 2007, 3:20 pm   #4
Leon Crampin
To enlarge on PJL's post a little, the external centralising "spider" on Celestian 'speakers of this vintage was glued to the frame with animal glue which by now, usually lets go. This causes the 'speaker voice coil to go off centre and rub on the magnet poles - giving a scratchy sound. Due to the stiction caused by this, it's a lot worse at low volumes and may not be too bad at higher sound levels.
The centering device can be fixed quite easily with PVA glue. Apply DC to the 'speaker to move the cone outwards and apply the glue with a cocktail stick. Reverse the power supply and fix the ring temporarily with 4 small croc clips. Check that the 'speaker is properly centred (switch off power supply), then leave for half a day with the power supply energised to preload the joint.
This fix works well for all post-war Celestian 'speakers but go easy on the DC - don't move the cone by more than about 3mm.
Leon.
Leon Crampin is offline
Old 27th Oct 2007, 3:27 pm   #5
unitelex
Leon.
Thanks Leon,
Some neat ideas there for speaker repair, will take a note of that for the future. The current problem however is not the speaker, I've tried a modern speaker externally - same distortion present unfortunately
unitelex is offline
Old 27th Oct 2007, 3:32 pm   #6
Leon Crampin
Just missed your last post - so it's not the 'speaker.
The EL84 is not my favourite valve and is prone to grid current. The coupling capacitor must be above reproach and the cathode bias resistor checked - these often go high.
Run the set with a DVM set to DCV between EL84 g1 and chassis, volume at minimum. A good valve will give no more than about +50mV indicating a low value of grid current. Many will be worse than that - the value increasing wildly as the valve heats up. If you have less than 100mV after half an hour, it's probably OK.
The 6CH6 is a far better output valve. To use in a VHF61, shunt the cathode bias resistor to give a total of 100 Ohms. The theoretical shunt value is 225 Ohms, but you can take into account the inevitable error in the original bias resistor when you make your calculation. Rewire the base connections so that g2 is on pin 8 and pin 9 is earthed - this is dead easy to do on a VHF61.
You will need a large pot bead as a spacer so the valve retainer will fit - the 6CH6 is a bit shorter.
Beam tetrodes in my view are superior to pentodes in every way and I have yet to see even a high mileage 6CH6 with grid current. They're very cheap, too.
Leon.
Old 27th Oct 2007, 3:54 pm   #7
unitelex
OK -thanks for the ideas - will check the Cathode resistor and grid voltage now...
unitelex is offline
Old 27th Oct 2007, 4:02 pm   #8
unitelex
OK, at minimum volume,
G1 has 144mV
Cathode has 6.7V
Output valve is an Edicron K5LH5
Should I try a resistor to chassis on G1 to cancel the leakage current or is my only option to change the valve ?
Thanks
unitelex is offline
Old 27th Oct 2007, 4:05 pm   #9
unitelex
G1 has 144mV
Cathode has 6.7V
Thanks
It had been running for about an hour when I measured this - so fully warmed up.
unitelex is offline
Old 27th Oct 2007, 4:15 pm   #10
Leon Crampin
I would regard this value of grid voltage to be too high. If your cathode resistor is to spec. the anode and g2 current is 37mA which is OK but this value of grid current will cause partial rectification of the input signal at low levels - hence the distortion. You perhaps ought to do a final check on the value of the EL84 g1 to chassis resistor before you condem the valve but these resistors don't often cause trouble and can be miles off value with little ill effect.
Out of interest, let your set cool right down and re run the test. Often gas current increases as the valve heats up - sometimes alarmingly.
I would try a better EL84 if you can find a good one (I have loads of gassy ones) - or you could try my mod...
Leon.
Old 27th Oct 2007, 4:21 pm   #11
unitelex
Just measured G1 again and it was 70mV ??
Disconnected the grid coupling capacitor altogether and checked G1 again
now 50mV
Reconnected coupling capacitor, G1 now measures 50mV
Perhaps the valve socket need cleaning...
unitelex is offline
Old 27th Oct 2007, 4:44 pm   #12
unitelex
Grid voltage is now 44mV, and the distortion at lowest volume is much less apparent.
Can't say for sure whether the improvement was due to my probing of the valve socket pins (dodgy contact on the cathode?) or my disturbing of the coupling cap.
Anyway, I've replaced the cap that was there (should have been good as it was a modern 400V polyester) with a new one.
Will leave it to fully warm up again and see if the grid voltage stays in check...
I'll get a beam tetrode anyway and try your mod...
Thanks for you help Leon.
unitelex is offline
Old 27th Oct 2007, 5:34 pm   #13
Leon Crampin
When you switch your set off the electrode structure in the EL84 cools - in particular the control grid. When you switch it back on again, the grid current will be lower and may stay lower for some time - such is the nature of the problem. Positive feedback effects often take some time to stabilise, and often don't settle twice the same way.
The EL84 has copper grid rods and heat radiator plates at the top welded to the g1 rods in an attempt to keep the grid cool. Why Philips (in particular) continued to make these inefficient valves where energy is expended by electrons bashing themselves into non-aligned grids is anyone's guess. I suppose the pentode was a Philips patent and the beam tetrode an RCA patent - these Companies can be a pig-headed lot. (I used to work for RCA).
Best of luck with your VHF61 - very good sets. I have two, one with an EL84 (a good one) and the other with a 6CH6. The set with the beam tetrode sounds better.
Leon.
Old 27th Oct 2007, 5:51 pm   #14
unitelex
OK, Although it seems better for now, I'm convinced enough to try the Beam Tetrode.
Thanks Leon
unitelex is offline
Old 27th Oct 2007, 7:23 pm   #15
PJL
It sounds like there was a bit of gas in the valve. As long as there is sufficient gettering this will normally burn off with a little use. This is a common problem even mentioned in Langfords book from the 50's...
Unlike power cords as some would suggest, this is an example where electronics really does need time to be broken-in ...Peter
PJL is offline
Old 28th Oct 2007, 8:44 pm   #16
unitelex
Leon.
I got a couple of Brimar 6CH6's from George at the Manchester Swapmeet today. Just tried your suggeted mod Leon. It certainly works and there is no low volume distortion noticeable
Would I be right in noticing slightly more pronounced treble?
Thanks,
Chris
unitelex is offline
Old 28th Oct 2007, 9:03 pm   #17
Leon Crampin
You could be right, Chris, but the 'speaker in the VHF61 is not world class - even with the suspension in good order.
I'm glad the 6CH6 mod is working well - are you able to re-measure the grid voltage (cold and hot) to check my theory?
I would stick a label on the chassis or mains transformer stack to indicate that the output valve type has changed -an EL84 in there now would not be good.
I have a huge bag of pot beads which are perfect as spacers if you want to fit the retainer. Send me a pm and I'll post you one.
Leon.
Old 28th Oct 2007, 9:41 pm   #18
Tim
Tim's Avatar
Nice one Leon. I'll remember that one as I have a quantity of CV2127s in the loft. I might even try it on my VHF 61 (which is currently missing it's EL84. ISTR replacing the speaker on my VHF61 some 20 years ago, but can't remember if it went o/c or distorted.
Tim is offline
