31st Aug 2019, 12:58 pm | #1 |
Head Cleaning
Hi can I use electrical contact cleaner to clean my vcr heads. It contains Methanol, Isopropanol & DME Thanks.
31st Aug 2019, 1:02 pm | #2 |
Re: Head Cleaning
I'd counsel otherwise - some contains lubricant i.e. leaves a residue. The most prudent approach is to use fresh IPA on a clean/new small piece of chamois leather. (And use clean surgical or plastic/vinyl gloves too ..... the oils and perspiration on your fingers is/are both a contaminant and corrosive ....). Be very gentle .......
Red to red, black to black. Throw the switch and stand well back! |
31st Aug 2019, 1:18 pm | #3 |
Re: Head Cleaning
Thanks I presume IPA is ISOPROPYL ALCOHOL had to look that up. Would this be obtainable at a chemist. I think cleaning is required has I have lost colour and I have tried tracking but that doesn't help Thanks
31st Aug 2019, 1:26 pm | #4 | |
Re: Head Cleaning
You could try though. Easily bought off eBay and probably from Amazon as well. Peter |
31st Aug 2019, 1:33 pm | #5 |
Re: Head Cleaning
Thanks for all your help will try amazon and ebay.
31st Aug 2019, 2:18 pm | #6 |
Re: Head Cleaning
IPA or Methylated spirits are both excellent, and Meths is easily obtainable and that is what I tend to use the most..
I must confess I don't understand the difficulty of buying IPA from a chemists shop given the CPC, RS, Farnell, eBay and Amazon sell it freely. John |
31st Aug 2019, 2:24 pm | #7 | |
Re: Head Cleaning
Peter |
5th Sep 2019, 12:18 pm | #8 |
Re: Head Cleaning
Have cleaned head but player still only plays back in b/w although I know the tapes were recorded in colour .The machine is a Panasonic vcr dvd combi EZ49V. It will record but only black/white. Thanks.
5th Sep 2019, 8:35 pm | #9 |
Re: Head Cleaning
That sounds like a copyright problem or leads or if you've not touched your settings an electronic issue....I doubt it's the heads but I'm no expert sorry...
6th Sep 2019, 7:01 pm | #10 |
Re: Head Cleaning
Assuming the correct model number is DMR-EZ49V.
Is it switched to SQPB in the menu, by any chance? |
7th Sep 2019, 12:37 pm | #11 |
Re: Head Cleaning
It was I have just altered to off, no change, also the remote sometimes doesn't work checked batteries etc. Possibly think the machine has probably had it. Thanks.
