Old 11th Aug 2020, 8:12 pm   #1
LXSTEIN45
Default Help with Invicta valve set
Been given this Invictus valve set to play with. It is an old bakelite mains driven set (dropper resistor) and I wonder if anyone might recognise the model so I can find a diagram for it?
Photos were a bit of an afterthought, I wanted to attempt a cleanup as it is very sticky, I assume a combination of vigh voltage, wax caps and probably a once smokey atmosphere!
It has 5 valves and will get a pic of the back end if that helps.
ID:	213271   Click image for larger version
LXSTEIN45 is offline
Old 11th Aug 2020, 8:27 pm   #2
Gridiron
Default Re: Help with Invictus valve set
Invicta Model 200 (According to "Radio Radio" identical to Pye Model 47X).
Gridiron is offline
Old 11th Aug 2020, 8:37 pm   #3
LXSTEIN45
Thank you sir!
Old 11th Aug 2020, 10:48 pm   #4
AC/HL
AC/HL's Avatar
Default Re: Help with Invicta valve set
Here: https://www.service-data.com/section.php/3937/1/200
AC/HL is offline
Old 12th Aug 2020, 3:42 pm   #5
LXSTEIN45
Would anyone mind offering some advice please?
Old 12th Aug 2020, 4:00 pm   #6
Graham G3ZVT
Graham G3ZVT's Avatar
At last!
The radio on our kitchen shelf for the first 7 or so years of my life,
I had no idea of the make & model until now, just a vague memory.
Thanks guys.
Graham.
G3ZVT
Graham G3ZVT is online now
Old 12th Aug 2020, 4:14 pm   #7
Apart from the usual change all waxies and check resistors not much really and of course switch cleaner!
Old 12th Aug 2020, 4:34 pm   #8
Graham G3ZVT
Looking at the Radio Museum circuit, change the three electrolytic caps, one is prominent on your picture and the other two are mounted on the speaker.
More pictures in this thread
https://www.vintage-radio.net/forum/...d.php?t=152716
Change the tubular wax capacitors, but leave the flat ones undisturbed.
C23 on the RM sheet is "That Capacitor" change this as a priority.
Are you aware of the safety issues when working on live chassis sets?
Graham.
G3ZVT
Old 12th Aug 2020, 4:52 pm   #9
LXSTEIN45
Ta Graham. I was going to replace all the waxy's tbh.
Couple of the Q's I wanted to ask. There appears to be no filter on my radio C27/28 & L7 and wonder if this might have been ripped out when it was rewired or if some radios just didn't have them?
Also, R16 in my exaple compromises two 12ishk resistors in parallel. on that very diagram it is a 15k. I was going to replace this with a 15k 3w resitor.
Some of my resistors are a little high too so will replace them all. I assume unless stated 1/2 watt metal film should be adequate?
Old 12th Aug 2020, 4:58 pm   #10
AC/HL
AC/HL's Avatar
It's slightly unusual in being permeability tuned. Be careful with the soldering iron!
AC/HL is offline
Old 12th Aug 2020, 7:21 pm   #11
LXSTEIN45
I am trying not to disturb the mica caps but I was expecting to have to re-align tbh!
This is my first valve radio restoration though. I have done many amps previously but radios have generally not needed touching in the past other than simple straightforward faults!
Old 12th Aug 2020, 9:28 pm   #12
To get "out of the box" performance it may be necessary (emphasis on the may) otherwise if it gets radio stations well there is no need.
Old 13th Aug 2020, 9:21 am   #13
MurphyNut
MurphyNut's Avatar
I have one of these though mine is the Pye version, this might be of interest-
https://www.vintage-radio.net/forum/...d.php?t=165649
Clive
MurphyNut is offline
Old 13th Aug 2020, 10:00 am   #14
PJL
The canned electrolytics used for HT reservoir and smoothing are pretty reliable so I would not replace these unless you have confirmed they are faulty. You should bring them gently back to life using a basic capacitor reformer.
PJL is offline
Old 13th Aug 2020, 11:13 am   #15
Gabe001
If you, like me, don't have a capacitor reformer there is a post on a cossor 464 thread which explains how to do this. I'm posting a screenshot for you for reference.
I always use a lamp limiter for the initial switch on, it helps me control the voltage better amongst other things
Name:	capacitor reforming.jpg
Gabe001 is offline
Old 13th Aug 2020, 3:37 pm   #16
LXSTEIN45
Originally Posted by MurphyNut View Post
I have one of these though mine is the pye version, this might be of interest-
I had been there already. You did a cracking job! Can you comment on the input filter I mention above, along with the two resistors in parallel?
Just waiting for my Farnell order to arrive. Was a bit dissapointed with RS's availability of reasonably priced caps tbh!
Old 15th Aug 2020, 8:06 pm   #17
LXSTEIN45
Thank you for that. I suspect this has not been powered up for a number of years, so I will take a great deal of care when I get to do so!
Old 18th Aug 2020, 12:38 pm   #18
LXSTEIN45
Hi folks Manual says C19 .01 but looking at this cap it is 0.001u?
Old 18th Aug 2020, 4:25 pm   #19
LXSTEIN45
it's ok the marking was hiding behind some wax. ****** hell it's hard work replacing parts in these little radios!
Old 18th Aug 2020, 6:30 pm   #20
unitelex
You can scrape the wax off with a screwdriver and the printing on the paper sleeve underneath becomes clear.
Since you are local to me you are welcome to do the alignment at my workshop if you have not got the equipment. I have a PLL sig generator.
Best Regards
Chris
unitelex is offline
