11th Feb 2019, 12:23 pm | #1 |
Old selenium rectifiers
I have a quantity of old selenium rectifiers. Is there a way of testing them to see if they are worth keeping or should they be assumed too old to use and be disposed of. They may be good to "fill a hole" to maintain originality using a silicon by-pass, but better to be actually used if possible.
Neil
11th Feb 2019, 12:39 pm | #2 |
Re: Old selenium rectifiers
As an example i bought an elderly battery charger with 12v/6v/2v tappings, and a big green painted selenium rectifier. We 'scoped the output and it was a perfect full wave rectified trace, such that it was put straight into service. I think that very many of them will be ok. If they look uncorroded suggest energising them, and using a 'scope. If they start to smell switch off and ventilate the room!
Dave |
11th Feb 2019, 12:54 pm | #3 |
I thought battery chargers used copper oxide rectifiers due to being more suitable for low voltage high current. Probably replaced by silicon now.
Frank |
11th Feb 2019, 12:55 pm | #4 |
I don't think it's worth trying to use them in anger, though as you say they might have a cosmetic use.
11th Feb 2019, 12:57 pm | #5 |
The big old ones with fins may be copper oxide, not selenium - and basically, if they work under load fair enough. Not so keen on the small contact cooled types though - they`ll certainly fail sometime soon.
