29th Dec 2009, 6:05 am | #1 |
Murphy B40 Hum cure.
By ensuring that the Heater return wire was *not* earthed to the power supply chassis, but only earthed in the IF chassis, I was able to eliminate the annoying hum that the set designers have gone to great lengths to reduce.
To do this it is only necessary to snip the earthing wire on one of the Jones sockets on the power supply, although a purist would, of course, desolder the wire neatly. Cheers! Don. Last edited by Darren-UK; 29th Dec 2009 at 12:11 pm. Reason: SKB problem fixed. |
29th Dec 2009, 11:48 am | #2 |
Re: Murphy B40 Hum cure
Errrrrr. Mine doesn't hum. Are you sure that there isn't another problem?
Alan |
29th Dec 2009, 3:11 pm | #3 |
Re: Murphy B40 Hum cure.
Glad someone else said this before I commented - I have never had aproblem with hum on any of the B40s I have repaired over the years - must be into double figures by now....
How strange. Sean
29th Dec 2009, 4:17 pm | #4 |
Being an ex RN Radio Mech from the B40 era I can second that. I never came across a B40, B41 or 62B that had any hum problems. Just those damn turret contacts!
Les
Whether the Top Cap is Grid or Anode - touching it will give you a buzz either way! |
29th Dec 2009, 5:25 pm | #5 |
Hi.
My B40D doesn't hum, I'm surprised it doesn't, considering it was lying in water for 15 years. Sounds like you have a heater cathode short/leak and you cleared it by allowing the heaters to "float". Reconnect the wire and then try substituting valves, also chech valve bases for leaks. Cheers Trevor
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member Last edited by murphyv310; 29th Dec 2009 at 5:26 pm. Reason: grammar |
30th Dec 2009, 8:31 am | #6 |
That`s strange guys, I`ve dealt with three that had this problem, perhaps made worse by using a good quality loudspeaker. They were all B40B`s, which have more filtering in the power supply than the "A", if I remember correctly. removing the earth connection completely cured the problem. Thanks for your comments!,.................................Don.
29th Jan 2010, 11:25 pm | #7 |
No powersupply capacitors problem ?
The AGC switch sometimes causes extra humming noise but I don't know (for now) in which lever position (on or of). best regards Qwenix |
