Old 15th Jul 2019, 7:49 pm   #1
19Seventy7
19Seventy7's Avatar
Default LG LV210 VCR issue
My LG LV210 VCR isn't working as it should in the sense that it think's that it's always ejecting a tape, when there was no tape in there to begin with to eject.
It also wont accept a tape and wont "finish" it's eject cycle. Although the loading tray is at the door ready for the next tape.
Does anyone know what I can do to fix this?
Thanks
19Seventy7 is offline
Old 15th Jul 2019, 10:58 pm   #2
toshiba tony
toshiba tony's Avatar
Default Re: LG LV210 VCR issue
The 210 was a mono machine I think it used the same carriage throughout the range. Easy to sort. The cassette in switch is gummed up. There are two switches next to each other, one is record protect, the other cassette detection.
toshiba tony is offline
Old 16th Jul 2019, 1:08 pm   #3
19Seventy7
19Seventy7's Avatar
Thanks for the reply. I've opened up the VCR but I cannot find the cassette in switch.
(I don't know too much about VCRs)
I've attached a photo below if anyone can point it out on there please if possible.
Thank you
Old 16th Jul 2019, 11:34 pm   #4
Maarten
I think all switches are on the main pcb, beneath the deck.
Maarten is offline
Old 17th Jul 2019, 10:44 am   #5
Welsh Anorak
Welsh Anorak's Avatar
Also the mode switch is suspect if it's the rotary type. Open it very carefully using two screwdrivers and polish the contacts with Brasso. Some machines used opto mode detection and if so disregard this advice.
Glyn
www.gdelectronics.wales
Welsh Anorak is offline
Old 17th Jul 2019, 7:15 pm   #6
toshiba tony
Do you know what, Marten may be right. After many years working for LG must have left me daft, I thought the record protection and cassette switches were clearly visible when the whole deck was removed. A ribbon connected the head drum on the top and an 8 or 10 pin connector to the main board carrying capstan info, end\start sensor, there was two decks fitted, non interchangeble.
Old 17th Jul 2019, 8:58 pm   #7
19Seventy7
19Seventy7's Avatar
I have opened it up and found it is a rotary switch. I opened it and polished it, but no luck. It did change to say there was no cassette in, so I put a cassette in (that I didn't care about) and it loaded halfway and got stuck. Wouldn't eject, wouldn't load further. I had to get the tape out manually.
I think there may be an issue with the mechanism because I've noticed that it seems very loose. Before it was quite tight and springy. (I noticed it was loose before inserting the tape) and when it was on, the arm the pinch roller sits on kept moving back and forth.
I'm not sure what to do next
Thank you for your help. it's really appreciated
Old 18th Jul 2019, 8:47 am   #8
Welsh Anorak
On this machine you can remove the mechanism as you've found out. Get an old tape and carry out the whole loading process by hand - tedious, but it will soon show you where and how the problem's occurring. Favourites are misaligned carriage gears - especially if someone 'got the tape out' - or the back tension arm in the wrong position, jamming the loading arms.
Glyn
