Old 25th May 2020, 12:07 pm   #1
stuart_morgan_64
Default Cooker ring element help
I have a element leaking to earth, I don't mind cutting, fitting grinding. Just asking for suggestions, of what to use as a replacment. I wondered if damp, how long may i need to leave it powered to dry out? Any help please. It is 7"
ID:	206735   Click image for larger version
ID:	206736   Click image for larger version
stuart_morgan_64 is offline   Reply With Quote
Old 25th May 2020, 12:24 pm   #2
Default Re: Cooker ring element help
Your best bet is to take the element along to somewhere like Ajax Appliance Spares in Ipswich and see if they can recommend a replacement.
If left powered up some elements get better and some get worse as far as earth leakage is concerned.
I'd check that your cooker is earthed and that your RCD is functioning, just in case!
Keep the soldering iron hot.
Old 25th May 2020, 12:46 pm   #3
stuart_morgan_64
The element got worse. Had it connected to a isolation transformer. Ajax has changed somewhat, not sure if they have the same helpful staff they used too. Last time they couldn't help without model number. Wanted bkue and red spot dryer toc s.
Old 25th May 2020, 12:49 pm   #4
Rings are generally specified by number of turns and wattage. Plenty of elements for sale online with pictures. You may find something you can modify.
https://www.ebay.co.uk/itm/7-INCH-CO...oAAOxyTjNScT7~
Old 25th May 2020, 1:28 pm   #5
TonyDuell
I think those plug-in ring elements are close to unobtainable now (I couldn't get one about 25 years ago anyway). The normal repair is to get an element of the same power (or close to it) and diameter and join it to the old housing and plug pins.
I found a few ring elements when I cleared my late father's house. I think 2 or 3 screw terminal ones about 6" in diameter and a larger plug-in one. All brand new. They are currently sitting on a shelf here (I never throw anything away that might be useful). If anybody wants them I am happy to give them away but they will have to be collected (after Lockdown has been eased).
Old 25th May 2020, 1:47 pm   #6
BRASSBITS
try Backer in Rotherham if they don't have one (highly unlikely ) they will make you one
BRASSBITS is offline   Reply With Quote
Old 25th May 2020, 3:09 pm   #7
stuart_morgan_64
I never think of the manufacturer.
Old 25th May 2020, 8:15 pm   #8
Ed_Dinning
Hi Stuart, e spares are normally pretty good for elements. (disclaimer)
Ed
Old 25th May 2020, 9:55 pm   #9
bluepilot
Often these rings suffer from damp if not used for a while. Simplest solution is to disconnect the cooker earth and turn them on for a while. Looks like you already tried powering it and that hasn't helped so that may not be the solution here.
A quick google (they can't touch you for it) turned up this place:
Cooker spares
They appear to have a 7" ring for all of a fiver.
Stuart
bluepilot is offline   Reply With Quote
Old 25th May 2020, 11:42 pm   #10
stuart_morgan_64
Thanks for the info. I will try again tomorrow to heat it up. Have had that problem before. I used a isolation transformer but its only 500w so voltage down a bit. Maybe a bit hotter for longer. May have to adapt a newer ring to fit. The support has to go under it though.
Old 26th May 2020, 5:46 pm   #11
stuart_morgan_64
I think I have found one, 7" 4 turn, which i think I can make fit, will have to cut the ring off, and make new holes, as I dont think I will be able to open the connection ends up. Ordered so will see
Old 27th May 2020, 2:58 pm   #12
paulsherwin
paulsherwin's Avatar
Cooker spares
A reminder that operating an electric cooker without an earth connection is a potentially dangerous procedure. It should only be done in a controlled environment by people who understand the risks - if you're in any doubt, don't do it.
paulsherwin is offline   Reply With Quote
Old 27th May 2020, 5:52 pm   #13
rambo1152
rambo1152's Avatar
Indeed.
Our last hob had solid hotplates and I got fed up with doing the above procedure, usually just before xmas when we needed all four hotplates working.
That amount of earth leakage would not have even been recognized as a fault in the days before RCDs, now it's a serious inconvenience.
Since then we have a new kitchen with a new hob. Can I extol the virtues of the induction hob for those who've never used one?
The responsiveness & controlability of "The fuel that dares not speak its name" in the forum.
"Flat screen" cleanability, and if it does go wrong it's like four simple TV line output stages inside, usually needing an easily obtainable transistor and bridge rectifier.
Graham.
G3ZVT
