11th Nov 2008, 5:09 pm | #1 |
Ivory paint on Philips 371A knobs ?
Hello,
I am currently writing up my restoration of a Philips 371A for the Success Stories column as the set (except for its badge) is finished. In Tony Thompson's excellent book there's a nice picture of a 371A and its round knobs have ivory paint decoration on them. Every other 371A I can find pics of don't have that decoration, indeed I couldn't find any trace of paint on the knobs on my 371A except for the waveband knob. I have painted them now, and with difficulty cos there's not really a place on them for a coachline, so does the 371A really have painted round knobs ? If not I'll take it off as I don't think it looks right. Howard |
11th Nov 2008, 9:44 pm | #2 |
Re: Ivory paint on Philips 371A knobs ?
Hi Howard
My 371a does not have painted knobs. Only the wave change knob on the right hand side has a single painted line. Terry |
11th Nov 2008, 10:15 pm | #3 |
hi howard, its possible that the white circles on the knobs had worn away from sixty years of use regards maitiu.
11th Nov 2008, 10:17 pm | #4 |
Thanks Terry,
That's one without paint decoration on the knobs. The Philips sets built in Holland and Switzerland in the same designed case did have painted knobs but were also painted around the dial but not along the top and bottom of the case.... Does anyone actually have a 371A with decorated round knobs ? I shall keep the lid on my Nitromors paint stripper can until tomorrow evening ..... Howard |
11th Nov 2008, 10:23 pm | #5 |
Hmm... Are the circles painted on the centre face of the knob? I would have thought there would still be traces of the paint if they where as it would only be the sides that get worn by fingers.
Cheers Lee
Lee |
11th Nov 2008, 10:26 pm | #6 | |
That is a possibility, particlularly the knobs on the front which would have had the most wear and tear. There was none though on the round tone control knob on the left-hand side yet almost all the original paint had survived on the waveband knob on the right-hand side, as had the paint on all the 371A waveband knobs that I've seen seen to date Howard |
11th Nov 2008, 10:35 pm | #7 | |
Hello Lee, This is how the knob on the 371A in Tony Thompson's book appears ... https://www.vintage-radio.net/forum/...1&d=1226439196 I agree with you, the paint is tucked well inside the surface of the knob so wouldn't have been exposed to much wear, but then it might simply have dropped out .... Hiward |
11th Nov 2008, 10:49 pm | #8 |
There is an article about the restoration of a 371A in the BVWS Bulletin, Vol 32 No2 2007, page 23. That set had its knobs painted although the restorer was unsure if this was original, looks OK but... .
Regards, Mick. |
11th Nov 2008, 10:55 pm | #9 | |
Thanks Mick, maybe that's the one in Tony Thompson's book ! I still have my doubts that that's correct. Probably the only way of confirming the original finish is to see a pic of the set in some 1948 sales literature. Howard |
11th Nov 2008, 11:02 pm | #10 |
Definitely not ! I have seen quite a number of these sets ( also have had three thro' the workshop ) and the paint has not present on any of them - indeed as you say there is nowhere on the moulding to run a paint line into - There were some Philips sets which had these but these knobs are moulded differently.
Andy |
11th Nov 2008, 11:09 pm | #11 | |
I reckon you're spot-on and so I will clean off the paint tomorrow. I personally think it looks better with the plain knobs. Howard |
12th Nov 2008, 10:42 am | #12 |
Hi Howard !
I, for one, would use a mechanical way to remove the paint rather than a chemical one. You can easily melt this old plastic with any solvent... Just my 2 cents.... |
12th Nov 2008, 11:05 am | #13 |
I agree with Andy etc. i.e. no paint on the round knobs.
BTW, the "tramlines" on the set itself take seconds to do if you carefully mask the edges with well pushed-down Sellotape first. Tony's book is fantastic and contains loads of really beautiful photos, but as you would probably expect, a few of the more heavily-restored sets have wrong knobs or grille cloths, for example. Nick. |
12th Nov 2008, 12:05 pm | #14 | |
I got the paint off, a gentle soak in warm water with mild detergent for 10 minutes and it peeled off easily. Nitromors is safe to use on bakelite but will destroy most other plastics, so yes, one should be careful using it as many radios had bakelite cases but their knobs were made from other plastics. Howard |
12th Nov 2008, 12:15 pm | #15 | |
Sometimes I use my Tamiya masking tape to mask off coachlines but one always gets some leakage and it's still necessary to scrape off a little paint along the edges. I don't use sellotape cos it leaves goo behind when it's removed. I often use Tony's book as a reference and it really is excellent ..... but then I would say that as many of the pics in it are of my sets Howard |
