24th Aug 2008, 1:48 pm | #1 |
SMD Cap id.
Hi, i need to replace a faulty SMD electrolytic. It has 226v printed on it, what value is this?? Cheers, Malc
Malc Scott |
24th Aug 2008, 9:36 pm | #2 |
Re: SMD Cap id.
Almost certainly 22uF.
It works the same as the resistor colour code system if you directly substitute numbers for colours, and gives the answer in pF. Thus, 2 (first figure), 2 (second figure), 6 (number of zeros) - 22,000,000pF or 22uF. Voltage isn't given - you'll have to decide this from the circuit! |
25th Aug 2008, 9:48 am | #3 |
Re: SMD Cap id.
A little tip for replacing these is to use two irons at the same time, this considerably reduces the risk of damaging the board.
25th Aug 2008, 1:39 pm | #4 |
Re: SMD Cap id.
Hi, many thanks Kalee. A 22mfd did the job. Michael, i tried your method and it works great This thread can now be closed. Cheers, Malc
Malc Scott |
