20th Nov 2008, 9:16 pm | #21 |
Re: CFT lamp interference with long wire antenna
Maybe because there's a filter network in the microwave that's permanently connnected to its mains lead, and its socket has only single-pole switching, leading, in effect, to some capacitor being connected between N and E
20th Nov 2008, 11:27 pm | #22 |
are you sure the wall socket is wired correctly?is phase connected to socket switch,regards maitiu.
21st Nov 2008, 10:12 am | #23 | |
The switch in the socket is only interrupting the live pole. The µW's internal EMC filter has a capacitor between neutral and earth, which is just enough to prevent the neutral wire of the lighting circuit from radiating anything. If that is what's really happening, then a 10nF Y-rated capacitor installed in the fusebox or a ceiling rose should have the same effect.
24th Nov 2008, 8:45 pm | #24 |
Hello,
An update on my original problem; RF interference on MW & LW after darkto the extent that programmes were unlistenable, blamed rightly or wrongly on compact flourescent lamps. On inspection the three core replacement mains cable I had installed had, contrary to my memory, not been connected to anything leaving the set unearthed! So, I have done the following with good effect: an external earth of a metre and a half of water pipe hammered into a flowerbed connected to the set's earth socket, sixty feet of external antenna draped along a hedge, a British Telecom filter plug adapter in the mains lead connected to the house mains earth, the mains lead to the set wound five times round a ferrite toroid (one sold for the purpose). I have left the set unconnected to the mains earth. The result is greatly improved after dark reception with none of the chopped noise there used to be; the only noise tonight being some background computer hash (and Radio Moscow on 199 kHz). Alan. |
24th Nov 2008, 9:11 pm | #25 |
Yes, and very strongly, too! Glad you got the problem fixed.
Al |
