21st Feb 2020, 4:05 pm | #1 |
Valve identity help
I have this valve in my collection which has no identifiable numbers. Could it be a PX4? Is there any way to positively identify it. I will await answers from the experts. Many thanks, Norman
21st Feb 2020, 4:09 pm | #2 |
Re: Valve identity help
Definitely a PX4
21st Feb 2020, 4:11 pm | #3 |
Looks like a PX4 to me - you could check the heater resistance but you would need to know what it should be, cold, which will be quite low.
21st Feb 2020, 4:40 pm | #4 |
It certainly looks like a PX4 - nice condition too.
21st Feb 2020, 4:42 pm | #5 |
Another way to come at it is to ask what it might be if it's not a PX4. I don't think there are very many alternatives are there ?
Cheers, GJ
http://www.ampregen.com |
21st Feb 2020, 6:05 pm | #6 |
The markings will probably be on the opposite side to the label.
21st Feb 2020, 7:04 pm | #7 |
Stick 4V on the filament pins (start with 2V just in case....)* and see what lights up. Hopefully it will be all of the filament though even if it's only half it could still be used to breathe lower powered life into an old radio.
* Remember the AC042!
21st Feb 2020, 8:26 pm | #8 |
Deff px4, you could try shining the light from an led torch on the glass envelope, it can sometimes pick out the faded numbers.
Greg.
Picture, sound?, DOOR. |
21st Feb 2020, 8:39 pm | #9 |
I have tried shining a light on it and also tried a uv light source but can’t see anything. I will have another look tomorrow. Norman
21st Feb 2020, 9:37 pm | #10 |
I think the only options are to try the filament as Chris says, then find an old enough radio to try it out in.
If you loaned it to an audio aficionado to try out and see if they recognised it by rhythm/pace/authority/granularity and speed of bass, you'd never get it back off them. It's got to be a triode with that number of pins.... did any half-wave rectifiers look similar? David
21st Feb 2020, 10:14 pm | #11 |
With the valve fairly cold breath on it ,may reveal a faint ID.Les
22nd Feb 2020, 8:03 am | #12 | |
You will have to measure the filament current to know. A PX4 draws 1 Amp at 4 volts, the PX25 draws 2 Amps. Either way a nice valve to have.
Never Leave Well Enough Alone... |
22nd Feb 2020, 10:16 am | #13 |
PX25s are significantly taller....
27th Feb 2020, 7:52 pm | #14 |
I also think it's a PX4
...where on earth did that spring/screw go?? |
27th Feb 2020, 7:57 pm | #15 |
I am fairly sure it’s a PX4, with 4v heater it draws about 950ma. I have a Taylor valve tester and will give it a go and see how it tests. I will report back with the results. Norman
11th Mar 2020, 6:17 pm | #16 |
Hi Folks, To bring this to a conclusion and after repairing my valve tester I have the following results. I don't know how well valve testers compare to book figures.
I have the following result, PX4 mutual conductance reads 4, book states 3.5 I also have a PX25 mutual conductance reads 1.5, book states 4. Is this likely to be duff or is it a case of it may work ok in something. Looking forward to your opinions please. Norman |
11th Mar 2020, 6:56 pm | #17 |
Sounds like a good PX4
And a tired PX25 The PX25 will probably still work to some extent in a single ended application and look the part at least.
