25th Jan 2023, 1:07 pm | #1 |
Rechargeable batteries in Hacker trannies
I've just read a post on the Facebook Hacker Radio Group page where a guy has put rechargeable PP3 Li-ion batteries inside the emptied out normal, large ones and it seems to work well apparently. It seems a great fix. However he does say that the battery is actually only 8V although it works fine with his Hunter RP38A. Is this likely to be a fix for most Hacker transistor sets? Any comments or suggestions?
25th Jan 2023, 1:15 pm | #2 |
Re: Rechargeable batteries in Hacker trannies
There are probably 2 cells in there, which would give about 8V when charged.
Most 9V sets will run perfectly happily on a couple of LiIon cells of any type, including 18650s scavenged from old battery packs and cells from disposable e-cigs. You just need to take them out and charge them every few months - they last for ages and don't self discharge. This has been discussed in previous threads. |
25th Jan 2023, 1:25 pm | #3 |
Thanks Paul. I didn't know it had been discussed previously. But anyway, this guy has made a really neat job of doing it, and it's easy to just hook up a USB lead even while the set is running. The PP3s have the small USB sockets fitted to them.
25th Jan 2023, 1:30 pm | #4 |
Yes, that would make life easier. I run my bathroom Party Boy on a couple of 18650s which I remove and charge externally every 6 months or so. USB charge controller modules can be bought on eBay for pennies.
25th Jan 2023, 2:01 pm | #5 | |
Presumably it needs an individual charge controller for each of the LiIon cells? Mike |
25th Jan 2023, 2:17 pm | #6 |
It does not if you keep an eye on them and don't forget to charge them when you should. You could put a small BMS across and that would do the trick and prevent discharging it too much.
I've put two used 18650 in my Panasonic radio(few post down the list from this one) and added a step up converter and it does work well. Step up converter just keeps the output voltage at 4.5V(which was what 3x C type batteries originally supplied). Two 18650 cells provide anything up to 4.2V(when fully charged) so without BMS I just need to make sure that I don't discharge the 18650 below 2.5V as that could cause damage to them. |
25th Jan 2023, 2:19 pm | #7 |
That's how I charge mine. The two cells are in holders and I remove them to charge them individually.
Actually, I have another pair of 18650s which I keep charged. Every few months I swap the cells over and charge the used ones. That way, the radio isn't out of use while the cells charge. I don't use a BMS. I just charge the cells before they have the chance to discharge excessively. I do use a safety fuse though. |
25th Jan 2023, 5:58 pm | #8 |
For anyone worrying about the 8V thing, just take a look at this graph:
https://commons.wikimedia.org/wiki/F...rent_100mA.svg An alkaline cell doesn't sit at 1.5V for much of its life! Just a fleeting moment, really. It pretty quickly gets down to 1.3V, which is close enough to 8V for a 6 cell PP9, and there's still plenty of juice in the tank, as the picture shows. Well deigned devices will continue to work down to 1.1V per cell. The Hunter loses FM sensitivity as the batteries wear down, but will work well enough in a good reception area down to around 10 or 12V. Lithium batteries tend to have much flatter discharge curves than alkalines, so if anything, they'll give better performance until it's time to recharge. |
25th Jan 2023, 6:03 pm | #9 |
For my kludged '9V' battery-packs I use seven NiMH cells. I'm more worried about internal resistance causing the voltage to drop on high-volume peaks - but NiMH and Li-Ion cells have much lower internal resistances than a tired Leclanche primary-cell.
25th Jan 2023, 8:12 pm | #10 | |
I've been using 8 NiMH cells in my 9v Grundig Elite-Boy for years now without any apparent problems. Mind you, I do have a protective series-diode in the battery circuit. Perhaps I should also put in a series fuse? Mike Last edited by Boulevardier; 25th Jan 2023 at 8:17 pm. |
26th Jan 2023, 9:14 am | #11 |
I do the same, 8 NiMh but would always fit a series fuse, there's a serious amount of smoke waiting in the event of a short circuit
26th Jan 2023, 6:05 pm | #12 |
I used to run my Hunter on a pair of 6xAA battery packs fitted with Kodak zinc carbons which was fine until I had to replace the two lokfit transistors in the FM tunerhead. I did not have the exact types in stock so I fitted what I had. The audio had a tendency to warble if over run, following the repair it had become a bit supply sensitive. When I fitted a pair of Energiser PP9s (£5.99 here in Bath) the results were much more satisfactory.
Neil
