24th Jan 2023, 10:00 pm | #21 |
Re: At last! A KB “Toaster” radio.
Hi PJL. The switch isn’t completely open, there is a few Meg of resistance there, so hopefully it’s just oxidation or soot from arcing.
I have successfully “ bonked” switches by forcing them to switch a heavier resistive load such as a 150 watt incandescent lamp.
25th Jan 2023, 5:48 pm | #22 |
The actual switch on current surge of a 150W incandescent lamp is probably >10× its nominal running current so the cruddy contacts will get a serious kick to clear the crap.
The electrical equivalent of a good whack wi t'ammer
6th Feb 2023, 5:42 pm | #23 |
Hi gang. Had a good go at the “Toaster” on Saturday.
It now plays( although not very well at present) on both wavebands. It’s quieter than I would have expected and rather hard of hearing. LW works over the entire band but MW conks out about half way along. One or more low emission valves I suspect. As suspected the smoothing cap was very low on one half and totally open on the other. The only replacement I had that would fit in the clip is slightly longer, and is wire ended but works very well. The on-off switch worked after being forced to switch a 100w incandescent bulb. All waxies and Hunts mouldseals replaced and a couple of out of tolerance resistors.
6th Feb 2023, 10:08 pm | #24 |
“ After “ shot of the gubbins.
7th Feb 2023, 8:52 am | #25 |
Reading this with interest as I have one in the loft waiting for my attention!
John
GQRP Club 4704 - BVWS Member |
7th Feb 2023, 10:51 am | #26 |
Hello,
A few years back I found some discrepancies between a Toaster I was working on, and the service sheets. I did a post on the forum a few years back about these discrepancies and the Late Mike Edwards noted it for his records. Link to the thread on the forum: https://www.vintage-radio.net/forum/....php?p=1326187 I have the late Mike Edwards MW/SW FB15T Toaster, which sits proudly on my Black PYE ‘Black Box’ in the lounge! One day I’ll get a FB10FM FM Toaster, however, the rarity of which, must rival that of hens’ teeth. Terry Last edited by Valvepower; 7th Feb 2023 at 10:59 am. |
7th Feb 2023, 6:47 pm | #27 |
It also needed a replacement dial lamp(which moves with the tuning indicator, a nice touch), and an NOS 6X5GT as the original was extremely tired.
7th Feb 2023, 7:26 pm | #28 | |
23rd Feb 2023, 1:07 pm | #29 |
