31st Oct 2008, 12:24 am | #1 |
Windsor (Taylor) 45B valves charts.
Hi Guys.
I've been playing with my new toy today. Never had a valve tester before but I have so many valves in unknown condition in boxes it will be worth spending some time going through these. I've been sent some valve charts (thanks Station X and PPPenguin) and these are OK to some extent but do not tally with my tester for all valves. I have three 9-way switches on the front (0-9 so 10-way I suppose) but some valves in the charts call for more positions than this. For example I can test a PL38 using the settings 4, 0, 9 which is fine but a PL81 calls for settings 10, 10, 10 which I don't have. I can check an ECL80 using settings 5, 3, 0 OK but the ECL82 asks for settings 2, 0, 17. Again not enough switch positions...or am I being really thick and not reading these numbers correctly? Does anyone have charts for my version of the tester that I could copy/buy? Thanks for any info. Rich
31st Oct 2008, 12:46 am | #2 |
Re: Windsor (Taylor) 45B valves charts.
Hi Richard
I have a Taylor 45A it has 3 switches 0 to 9 as yours has. I am not able to test more modern valves on it ( EL84' etc.). I may be wrong but I believe that the charts that have the numbers above "9" are meant for a different model of tester that is capable of testing these types of valves. Frank |
31st Oct 2008, 1:08 am | #3 |
Richard,
The first part is HERE. I'll try and add the rest tomorrow - or rather later today! It states that it covers the Taylor/Windsor 45B and the Taylor 45A and 47A. (The pdf covering half the book is 5Mb - hence an offsite file) Agreed - the testing of modern valves is not always feasible because of the higher gains and frequency capability leading to oscillations - not only on account of bases and data. R |
31st Oct 2008, 1:40 am | #4 |
Later versions of the Taylor Valve Charts cover the Taylor 45A, 45B, and 45C valve testers; the 45C has ABC switches with 18 positions (0 - 17). If a chart entry has a circular symbol enclosing the number '13' then the settings apply only to 45C valve testers.
Unfortunately, unless you make special adapters, you will find that the 45B (and all but the latest 45Cs, unless modified) cannot test later B9A valves such as the ECL86, PY88, UL84, etc. I know of one brave individual who has converted a 45b into a 45c by removing the 10 position switches, and replacing them (presumably at considerable expense) with 18 position switches. Wiring them up must have been a nightmare. Edward Last edited by igranic; 31st Oct 2008 at 1:46 am. |
31st Oct 2008, 8:24 am | #5 |
Presumably the problem is that the 45B, unlike say an AVO CT160 with its roller switches, does not allow full flexibility in connecting test lines (A, S, G, C etc.) to valve pins (1, 2, 3 ,4 etc.)?
That being so would it not be possible to wire the test lines out to a patch panel? One half of the panel would have sockets labelled A, S, G, C etc. The other half would be connected to a valveholder/holders and labelled 1, 2, 3, 4 etc. This would allow full flexibility. Were the A, S etc sockets wired out to a plug capable of being plugged into one of the sockets on the 45B there would be no need to modify it.
31st Oct 2008, 9:10 am | #6 |
Ahh! I'm beginning to understand now! It's probably not worth modding the 45B to test later valves. It might be feasable to make some adaptors though if necessary. Mind you, with valves like EL84 where there are so many about it's simple to substitute when testing a set. On the other hand if you have a PEN4DD or a PM2A and no immediate replacement, then it's a useful piece of kit.
Rich.
31st Oct 2008, 10:46 am | #7 | |||
One thing that the British valve testers had in common was the ability to test the dynamic gM of a valve, whereas the majority of the US 'tube' testers simply tested cathode emission in a simple diode configuration (i.e. all other electrodes connected together). I believe the Taylor testers were a good compromise of price, functionality, and reliability, being somewhat less prone to accidental or abusive damage than their AVO counterparts. Edward |
