14th Sep 2022, 5:11 pm | #1 |
EMI TV end fed wire antenna.
I have vague memories of a TV antenna promoted by EMI in the early days of broadcast TV - it was a long-wire (meaning several wavelengths long) horizontal wire which you were meant to arrange so that it was radially oriented as a ' spoke on a wheel ' with the transmitter at the centre of the hub.
I guess it was a sort of Beveridge antenna.. But was it terminated by a proper resistance and quarter wave end?! And how effective would such an antenna be?!
14th Sep 2022, 5:44 pm | #2 |
Re: EMI TV end fed wire antenna.
If it's this one it looks as if it separates the radio and television aerials.
Peter |
14th Sep 2022, 10:20 pm | #3 |
The transmitting aerial at Alexandra Palace consisted wire elements attached to insulators.
Described as eight pairs of push-pull end-fed dipoles with reflectors. Pg195 https://www.bbceng.info/additions/20...V%20System.pdf Oddly for a document that describes the station in minuet detail, there is no diagram of the aerial.
-- Graham. G3ZVT |
14th Sep 2022, 10:59 pm | #4 |
14th Sep 2022, 11:17 pm | #5 |
The Ally Pally transmitter aerial was the subject of its own illustrated booklet, which possibly explains its absence from the posted document describing the station. I posted a scan of the aerial booklet on this forum some years ago but don't recall which thread. I couldn't find it just now using the forum search, so I guess it's gone. I do still have the original booklet, and its scan, but the scan is backed up somewhere on my old computer and the booklet is in a box somewhere in the shed.
Last edited by emeritus; 14th Sep 2022 at 11:44 pm. Reason: typos, mention of forum search added |
15th Sep 2022, 7:47 am | #6 |
15th Sep 2022, 8:46 am | #7 |
Some interesting antennas there, but the one I am thinking of was a receiving antenna for domestic use... A long wire, horizontal, fed using coax cable. Assuming that you had a long enough garden you arranged for the wire to have the far end pointing towards the transmitter...
15th Sep 2022, 9:14 am | #8 |
End fed Antennas are high impedance so a very poor match to 75 ohm coax. A balun would need to be constructed around 47:1 of course that's dependent on the length of the long wire.
Cheers, Trevor. MM0KJJ. RSGB, GQRP, WACRAL, K&LARC. Member |
15th Sep 2022, 9:15 am | #9 | |
Then in 1950 they produced a simple indoor one that might be the 5' section without the radio aerial. Peter Last edited by peter_scott; 15th Sep 2022 at 9:23 am. |
15th Sep 2022, 9:24 am | #10 |
I have the book 'Television Principles and Practice' by F.J. Camm dated 1955 and under the aerials section is a 'Tilted wire aerial' described as A long wire of highly directional properties which requires space for erection. Not a lot of details about it.
Adrian |
15th Sep 2022, 11:35 am | #11 |
On 8th February 2007, Ray Cooper wrote, in the thread "The earliest television aerials":
"The 'tilted wire' aerial - in effect, a vertical half-rhombic - could give very good results IF you had enough real-estate to erect one, and IF you could point it in the right direction. Those conditions satisfied, they could be a good candidate for home-construction. " I have a picture of this arrangement somewhere, taken from an old magazine, but I'm dmned now if I can find it! What sort of gain would this type of aerial have had on Ch.1? Steve
https://www.radiocraft.co.uk Last edited by Panrock; 15th Sep 2022 at 11:46 am. Reason: word order |
15th Sep 2022, 11:59 am | #12 |
A quick search on wireless history site. and there is an article in Wireless world. 1939 31st August page 206.
Adrian |
15th Sep 2022, 5:39 pm | #13 | |
If anything it was like the 'windom' or 'off-centre-fed' antenna; the memory's not 100% but if you were to put up a wire that was quite a few wavelengths long, then break it 1/4-wavelength from one end and attach your feeder across the break - looking at details of long-wire antennas in the Moxon book, the feedpoint woiuld be somewhere between 50 and 100 Ohms impedance, and the polar diagram looks distinctly gainy along the axis of the wire [unlike a classic dipole where the gain is greatest at 90 degrees to the axis].
15th Sep 2022, 7:55 pm | #14 |
The bit I have difficulty with is "The far end of the wire pointing towards the TX". Wouldn't that be a null point?
-- Graham. G3ZVT |
15th Sep 2022, 10:41 pm | #15 |
Here's a description of how to make a tilted wire TV loft aerial from Odhams "Radio Television and Electrical Repairs" book, 3rd edition, 1956. It does say that the aerial should slope towards the transmitter, and each half should measure 5' 4 1/2", making it about 10' 9" long overall, and specified twin feeder. By the time the book was published, Belling- Lee for one had discontinued 75 Ohm twin feeder.
Because the aerial slopes, the end-on null points dowards towards the ground, not towards the transmitter. The missing introductory paragraph on the previous page, which I haven't posted, says: "Fairly close to the transmitter, and where there is little interference, no reflector is needed and a " (continues with page 296 "cheap aerial ....). Last edited by emeritus; 15th Sep 2022 at 11:01 pm. |
16th Sep 2022, 9:05 am | #16 |
If the wire was several wavelengths long, it would become more 'end fire' than 'broadside', a la Beverage (although without the end termination). I doubt most ordinary people would have room for it though!
Andy G1HBE. |
16th Sep 2022, 1:09 pm | #17 | |
I've been looking around at places like http://www.earlytelevision.org/ which has some good examples of pre-and post-WWII TV antennas, and looking at the 1930s records of amateur experimentatioin on the then-permitted 56/MC/s band; several operators in the famous Snowdon trials were using end-fed antennas but I haven't been able to fond evidence of my V Long-Wire. [An incidental question: all the photos on earlytelevision.org show the US VHF antennas to be horizontally-polarised, but the UK ones are vertically-polarised. Why did the UK adopt vertical polarisation]
16th Sep 2022, 4:02 pm | #18 |
16th Sep 2022, 4:34 pm | #19 | |
Horizontal polarisation was used for UK Band-II FM broadcasting.... though from the 1870s there was a move towards slant polarisation so mobile/portable reception was better.
16th Sep 2022, 4:47 pm | #20 |
From the Wireless world article, this looks to be the same as an 'H'. Where it excels, however, is in its strongly directional characteristic. In a suitable location it could be much less prone to motor car interference.
Steve
https://www.radiocraft.co.uk |
