15th Oct 2020, 7:55 pm | #21 | |
Re: Belling electric fire, all three bars work.
15th Oct 2020, 8:58 pm | #22 |
Hi.
Back in the 1970s we had a late 1960s Belling electric fire of the type which incorporated a surround and shelves. It had 2 bar elements of open spiral construction 'protected' by an horizontal wire guard. Rising heat from two "fireglow" filament bulbs drove rotating aluminium blades to give the glowing coal effect. I quite liked that fire until I had an incident with it. Being an inquisitive youngster at the time, I wanted to find out how quickly the element heated up from cold. I kind of figured it was dangerous to put my fingers through the guard and onto the element but thought that if I briefly touched the element on the neutral side then I should be OK. The trouble was I tapped my fingers on to the live side. My hand flew out of that fire at about 100mph. It felt like someone had hit my arm with a large hammer and was aching for about three hours after. Needless to say I didn't try that again! That was at a time when the only protective devices were the plug and consumer unit fuses, no RCD protection. I luckily got away with that seeing my other hand was connected to earth via the fire's casing. Ah yes, like G6Tanuki's cat, I also recall our cat had, shall we say, a close encounter with the Belling and will never forget the aroma of cinged fur. Quite a lethal thing really but could easily have been made safe with enclosed elements and a guard with smaller wire spacings. Regards, Symon Last edited by Philips210; 15th Oct 2020 at 9:11 pm. |
18th Oct 2020, 2:49 am | #23 |
I have to wonder how your generation managed to survive into the 21st century with deathtraps like these, outdoor toilets and the level of hygiene implied by the phrase "bath night".
Those gory public safety videos must have really worked. |
18th Oct 2020, 12:26 pm | #24 |
The answer to that is that people just developed strong immune systems or died. There were still quite a few houses with only one outside loo when I was young. Next door to us they had an inside bathroom fitted and left the outside loo still in working order. Anyone that got too fat to fit in a tin bath could not get clean easily. The pipes remain in working order in our back garden although the loo itself was demolished long ago.
18th Oct 2020, 1:38 pm | #25 |
It helped your lateral thinking too. Although we dud have an inside WC, for baths we had the tin bath that dad used to have to carry upstairs on bath night. Mum used to fill with it water from the gas boiler, and emptying was bailing out using a large saucepan. After I learned about the syphon in physics at school, I used to empty it using the garden hose as a syphon, running it out of the window to discharge in the outside drain. My first practical application of science!
18th Oct 2020, 3:23 pm | #26 |
We appear to have lost interest in the fire, and as there can't be much more to be said about it anyway, time to switch it off.
