Television Standards Converters, Modulators etc Standards converters, modulators anything else for providing signals to vintage televisions. |
6th Oct 2022, 2:24 pm | #1 |
Does anyone know anything about "Modulation Depth"? (Philips PM5680)
Hello
I'm currently trying to throw together a setup to create an analogue telly Broadcast [by that I mean signal - not actual on-air transmission] (for fun). It's mostly based on Philips PTV gear (I have spammed these forums with links to my teardowns of them in the past). The latest piece I'm trying to grapple with is a Philips PM5680 modulator ( https://www.radiomuseum.org/r/ptvphi...5680_all.html# ). Usual problem - no manual available. I have one which is PAL-I capable but am a little confused about the modulation depth adjustment. I think I understand with the vision carrier, it's the ratio between the amplitude of the carrier tone and the video signal and I can see this clearly on my spectrum analyser. Some reading suggests 90% "modulation depth" is a good starting point. I'm a bit more confused about the audio side of things. It measures it in KHz instead of %. Basically I have no clue what this measurement actually is. Anyone have any experience of this? Last edited by inaxeon; 6th Oct 2022 at 2:32 pm. |
6th Oct 2022, 3:52 pm | #2 |
Re: Does anyone know anything about "Modulation Depth"? (Philips PM5680)
Isn't the audio signal frequency-modulated? This might be the deviation or something related to it.
6th Oct 2022, 3:55 pm | #3 |
PAL-I has FM sound, so the amount of FM is specified as the frequency deviation, usually in kHz.
Vision is amplitude modulated with the sync pulses being the greatest amplitude. With a colour signal, there has to be allowance in carving-up the amplitude cake to allow for the maximum chrominance voltage at 4.43361874MHz superimposed on the luminance ( DC component). Video isn't a symmetrical easy waveform like a sine or AC-coupled AM audio, It will have to undergo DC restoration at the receiver. So it's best to not think of an average carrier level. Think of the RF voltage at peak sync and the RF level at the black reference in the porches and scale everything from these. David
6th Oct 2022, 4:17 pm | #4 | |
I would have thought deviation from the carrier would be determined by the actual signal, not an adjustment on the modulator? |
6th Oct 2022, 4:21 pm | #5 | |
6th Oct 2022, 5:54 pm | #6 | ||
6th Oct 2022, 7:49 pm | #7 |
FM audio deviation is normally 75kHz, at least on the 88-108MHz band.
7th Oct 2022, 8:40 am | #8 |
7th Oct 2022, 9:16 am | #9 |
Would it be fair to say then, that the "pot" on the front panel is setting the frequency deviation of the maximum representable AF amplitude (as you state 50KHz in this case)?
7th Oct 2022, 11:02 am | #10 | |
Can you post a photograph of this part of the front pannel ? |
7th Oct 2022, 12:46 pm | #11 |
Inexeon wrote:
"I think I understand with the vision carrier, it's the ratio between the amplitude of the carrier tone and the video signal and I can see this clearly on my spectrum analyser. Some reading suggests 90% "modulation depth" is a good starting point." Is 90 per cent video modulation depth too much even for negative modulation TV systems? DFWB. |
7th Oct 2022, 1:12 pm | #12 | |
7th Oct 2022, 1:39 pm | #13 |
"At this point in time I don't even know what 90% is a measure of. I saw a mention of it somewhere (on these forums I think), also the summary datasheet from Philips pictures it set at 90%"
Peak white relative to zero modulation. Sync tips to maximum carrier level. DFWB. |
8th Oct 2022, 12:09 am | #14 |
This might explain things;
To avoid transmit overmodulation with chroma present, the modulation level is reduced. In the receiver the chroma gain can be increased in the RGB video stages. |
9th Oct 2022, 11:03 am | #15 |
Hi to all,
To illustrate this thread, here are photos (web search) of the Philips PM5680 TV modulator. From looking at the I/O connectors, the unit requires an RF TV channel input frequency and only accomplishes A/V modulation. The photos show a (possibly) multistandard unit with NICAM audio or German stereo/dual sound option. Best Regards jhalphen Paris/France Last edited by jhalphen; 9th Oct 2022 at 11:08 am. |
9th Oct 2022, 7:31 pm | #16 |
I'll probably end up doing a full teardown of it at some point. Here's a photo inside the front panel (Also attached):
https://xpander.mattmillman.com/file...ges/pm5680.jpg Regarding the Zweiton version. I've searched long and hard and cannot find a single documented example of this actually being fitted (Even to the multi standard units). I would guess the Netherlands is the only place such a thing could be found because if it were Germany it'd be Rhode & Schwarz :P In that photo the Zweiton audio (second channel) is done by the missing Unit 8. There is no option of NICAM. The "BW NICAM" Switch on the front (mine has this fitted) changes the composite video input filter to allow the NICAM carrier to be inserted through this input rather than through the IF. NICAM modulation is done by the PM5687 (which I also have. It is stacked on top it). Another point of interest is that Unit 10 can either be a fixed channel up-converter or a linearity corrector. I believe mine has the linearity corrector although as of yet I have no clue what this actually does. For the up-converting I'm planning to use this beast: https://www.mattmillman.com/a-quick-...-up-converter/. |
9th Oct 2022, 8:08 pm | #17 | |
Couple of points / questions: A) Looks like it's probably quite handy to have a colour bar generator to calibrate a modulator. B) The "weighting" that is described there. That I'd guess has to be done by the video source? |
10th Oct 2022, 10:38 am | #18 |
The weighting is not applied to the chrominance signal as a whole, it is applied to its components. The weighting factors are
0.877 applied to (R' - Y') and 0.493 applied to (B' - Y') these weighted signals are then referred to as V & U respectively. As to where these weightings would be applied, I am not sure, as I was only a humble TV repair person, and not a broadcast engineer, but I would suspect it was done inside your PM5680.
-- Graham. G3ZVT |
10th Oct 2022, 1:25 pm | #19 |
What you have there is the modulator rack from a full broadcast TV transmitter.
It takes baseband video and baseband sound signals and creates an IF signal having both video and sound modulated carriers. From this unit, the IF signal goes off to be mixed with a local oscillator to create a signal on the intended channel. Filtering is needed to remove the image product. and the rest is power amplification with harmonic filtering. Everything after this unit has to be carefully kept linear. The spare slot is either for a second analogue sound modulator for analogue stereo (or dual language) service. It could also be for a NICAM modulator for digital sound. The VSB filter means vestigial sideband. Broadcast TV has the sideband energy around the vision carrier trimmed asymmetrically so one sideband is more extensive than the other. So, what you have is fixed frequency and not on any used TV channel frequency. You need some more hardware to get there. David
10th Oct 2022, 1:53 pm | #20 | |
