Old 29th Sep 2020, 5:32 am   #1
Binnawan
Default Gambrell One Valver
I have acquired a one valve Gambrell 'receiver'.
Marked Gambrell Bros London and No 11461.
It has a PM22A in at the moment and 2 coils external (tickler?)
I can find no information on Gambrell one valve radios.
Pic will be posted asap.
Baz
Binnawan is offline
Old 29th Sep 2020, 12:41 pm   #2
coopzone
coopzone's Avatar
Default Re: Gambrell One Valver
Maybe:
https://www.radiomuseum.org/dsp_hers...ompany_id=5546
has something similar ? It maybe a case of reverse engineer it, should not be to bad with just one valve?
coopzone is offline
Old 30th Sep 2020, 12:51 am   #3
Binnawan
Thanks for the reply. The museum has nothing like mine. I could reverse engineer, that's not what I am looking for. I need ANY information, pics etc. I have never found any similar radio.
Binnawan is offline
Old 1st Oct 2020, 1:49 am   #4
Binnawan
Pics of Gambrell 1 valver
The radio has connections for ant, ground, headphone.
Controls, osc filament magnifier filament and tuning
Has a PM22A fitted.
place for presumably power leads at rear, not marked.
ID:	216740   Click image for larger version
ID:	216741   Click image for larger version
ID:	216742   Click image for larger version
Binnawan is offline
Old 1st Oct 2020, 10:13 am   #5
Herald1360
Herald1360's Avatar
The PM22 is unlikely to be correct since it's an output pentode, unless there's any original looking connection to its side terminal. A PM1HF would be a more likely candidate for a single detector with reaction set.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 2nd Oct 2020, 1:00 am   #6
Binnawan
OK thanks,
PM1HF seems to be a collector valve now and expensive.
I think this radio will be at the end of the queue for a while and be an ornament.
Baz
Binnawan is offline
Old 2nd Oct 2020, 5:18 pm   #7
Herald1360
Herald1360's Avatar
Pretty much any B4 based battery triode would work. Maybe just triode connect that PM22.
Or use an adaptor and try a triode connected 1T4 or similar 1.4V B7G bottle.
Nothing to lose and a bit of fun.......
....__________
