23rd Sep 2020, 3:22 pm | #1 |
Rogers RD Junior CH1 smoothing choke
Hi everybody
does anybody know the value of the RD Junior mono amp's choke? many thanks in advance Bruno |
23rd Sep 2020, 10:06 pm | #2 |
Re: Rogers RD Junior CH1 smoothing choke
If you mean this circuit, it's about 11 Henries. Remember that it only feeds HT to the ECC83 and a single valve in the pre-amp and valves in the tuner so it only needs to be a few tens of milliamps. If you intend to change the circuit and use the choke to feed the EL84s as well it will need a greater current capability.
There is a Japanese clone of the amplifier on the internet which uses a 30 Henry choke at 40 milliamps but that probably wouldn't fit inside the screening can. |
24th Sep 2020, 11:01 am | #3 |
Sounds like the primary of a small class A output transformer would make a suitable choke.......
25th Sep 2020, 12:18 pm | #4 | |
thank you all for the replies and pdf!
Bruno Quote:
