Old 27th Sep 2020, 8:32 am   #1
Dutchtrader
Default Hello. New to this Forum. Need help with HMV2328
Hi, we bought a HMV 2328 which is a Gram-Tape-Radio player. Serial 6124. The Gramophone with a Garrard 3000 deck works fine. Trying to get the radio to work. It seems to amplify and I think it is just lacking an aerial. I have no paperwork for it, so not sure how the aerial was attached.
In the deck area there are 2 sockets.
One labelled "Tape" with a 5 pin (female) I think DIN.
One labelled "Radio". Hard to tell possibly looks like an old Female Jack socket.
Any assistance on this appreciated.
Thanks
Richard
ID:	216484   Click image for larger version
Dutchtrader is offline
Old 27th Sep 2020, 10:21 am   #2
Default Re: Hello. New to this Forum. Need help with HMV2328
Hello and welcome to the forums.
Service data for your combo can be downloaded here:-
https://www.service-data.com/product...07/3820/e12707
Station X is offline
Old 27th Sep 2020, 11:46 am   #3
music-centre
Had one of these a while ago, FM radio only, there would be an internal aerial but I think with the wires brought out to a small 2 pin socket at the back so you could connect a better one.
You should get something with the internal aerial though, is it completely dead? try operating the radio switch a bit, the contacts get dirty.
They do use a couple of AF116 Transistors though which are unreliable now.
Steve.
music-centre is offline
Old 27th Sep 2020, 1:30 pm   #4
Having looked at the circuit diagram I can confirm that this set has an internal VHF/FM aerial with provision for an external VHF/FM aerial.
You'll probably find a two pin socket on the back of the unit somewhere with a flying lead from the internal aerial which plugs into it.
