7th Sep 2018, 3:31 pm | #1 |
Revox A77 capstan / motors weak
The capstan on this is pulsing , and the motors are really weak . Will this be a prob with the run caps ? It could be a number of things I guess I just wondered if the Revox guys here knew "oh that always this ". ..I vaguely remember replaceing the power transistor on the capstan board one one not too long ago. I think the motors are down to the bearings , no free spin with the brakes disengaged . So I`ll be swapping those for ones with new bearings .
David. Last edited by NorfolkDaveUK; 7th Sep 2018 at 3:54 pm. |
7th Sep 2018, 8:16 pm | #2 |
Re: Revox A77 capstan / motors weak
OK some more info and update . I`ve got the transport ticking along nicely now , as expected it was just the bearings , so swaped the motors out for ones with new bearings , still having the issue with the capstan though .
I`ve changed the power transistor and thats not cured it even though the emitter to base was open . I`ve replace the rifa cap and thats not cured it , but i`m not surprised the rifa`s all have the 2015 date stamp on them . I`ve changed the start/run caps and thats not cure it so I`m now looking for some advice and to what to check now . Thanks folks . David |
7th Sep 2018, 9:04 pm | #3 |
Does the capstan motor turn freely when the machine is switched off?
If so, if you ground the collector of the output transistor on the capstan control board, the motor should run at full speed, if it does not it means youve got a faulty capstan motor. |
7th Sep 2018, 9:33 pm | #4 |
Its not that I`ve tried 2 now , same thing .
Changed the capstan board out for another one . Jobs a good`n .. Thanks guys . |
8th Sep 2018, 10:32 am | #5 |
On some of those control boards, there is a tantalum capacitor which when it fails can produce some very odd results.
8th Sep 2018, 10:48 am | #6 |
Yeah I will diagnose it later on I just had a donor machine so it made sense just to pull it out . I changed the power transistor i thought it was that because it was open from emitter to base . So it need changing , I guess that may have taken out a cap or a resistor when it went open I dunno . Its working great now thats the main thing . I need to change the bearings on the motors , the good drums I have done fit the shafts so they will need changing .
