Old 26th Aug 2017, 10:40 pm   #1
majoconz
majoconz's Avatar
Default Unaohm Field Strength Meter FSM 5988
Hi Guys, this is probably not considered "vintage" but it's worth a try!
Anyone got a service manual or even just a schematic for this device. Dirt cheap on our local auction site, rather grubby externally but only dusty inside - given a good cleanup and switch cleaner on the pots and switches and it actually works quite well. The first mark on the level meter is 20dBuV but it's much more sensitive than that. Seems to have a TV tuner module inside and a reasonably large chip that's probably doing all the work. Frequency displayed down to 100kHz seems to be accurate. Continuous coverage from 46 to 860MHz. Case held together with Tinnerman nuts - all busted or missing - hopefully replaceable. Runs on 12 "C" cells and has a 5 minute timer on it which got me confused at the start! I thought it had an intermittant fault but it's intermittant on purpose!
Any help gratefully received - thanks.
Cheers - Martin ZL2MC
majoconz is offline
Old 27th Aug 2017, 12:50 am   #2
karesz*
Default Re: Unaohm Field Strength Meter FSM 5988
maybe here?
Regards, Karl
karesz* is offline
Old 27th Aug 2017, 4:08 am   #3
majoconz
majoconz's Avatar
Thanks for that, Karl, but been there, done that. I was momentarily excited when I saw the "Service" heading - expecting to find a manual download, but no - they wanted to service the meter for 70Euros analysis the 80Euros/hour to fix it! Not counting P&P of course!
majoconz is offline
