Old 7th Jul 2021, 10:37 pm   #1
HowardB
HowardB's Avatar
Default Ekco A104
Would you believe it, I was actually pushed into buying this one by my wife! That doesn't happen often. It was on eBay for £40. She suggested that I make a cheeky offer of £20 and they accepted.
It arrived a few days later and after a few basic checks, I tried running it carefully via a Variac and limiter, but no cigar. No output at all.
I separated the chassis from the cabinet and hoovered up all the muck and dust. Thankfully the underside of the chassis was clean and untouched.
The wooden cabinet had lots of scratches and looked its age but no major problems.
The main issue was the plastic front grille. According to the forum, this seems to be an issue on these sets. The plastic had shrunk, warped and cracked. The previous owner had tried to glue it back together and made a right mess of it.
So that's the 'Before' - see the pictures below...
ID:	237273   Click image for larger version
ID:	237274   Click image for larger version
ID:	237275   Click image for larger version
ID:	237276   Click image for larger version
HowardB is offline
Old 7th Jul 2021, 10:43 pm   #2
HowardB
HowardB's Avatar
Default Re: Ekco A104
I replaced all the waxy caps and a few resistors.
Replaced a couple of bypass electrolytics but left the original smoothing caps in place.
The rectifier (UY41) was replaced which restored the power supply.
By this time the radio was kind of working but with very low volume.
While I was testing it, I accidentally attached the aerial wire to the PU input and this strangely improved reception, making it a lot louder. That was weird.
I figured this might be caused by a switching fault, so I thoroughly cleaned the wavechange switch. That fixed it. It now received stations loud and clear on all wavebands and with the aerial in the right place.
The tear in the speaker was fixed with tissue paper and Copydex.
The dial back plate was cleaned and repainted.
The rubber bushes on the tuning capacitor were replaced.
But how to fix the plastic grille?
I went through several iterations on this. I had read that place mats could be used. I got a nice one from Wilko (£1.75) but didn't use it. Bought some nice speaker material and some foam padding, but didn't use that either. My next waste of money was wire mesh from B&Q that turned out to be too 'open'. I finally hit gold with perforated stainless steel sheet. This was the right thickness, had the right amount of holes and most importantly, it looked the part. It was however very difficult to cut, so in retrospect, I think aluminium would have been a better choice.
The cabinet was stripped back to bare wood using a mild paint stripper. I stained the front and sides with dark oak and the lighter middle sections with antique pine. Three coats of Danish oil followed, allowing the final coat plenty of time to dry. I finished it all off with a few coats of lacquer sprayed from a can.
All In all, a lot of work but I'm quite pleased with the results. I think the radio looks a lot better now and it certainly plays well with a lovely mellow tone.
HowardB is offline
Old 7th Jul 2021, 11:55 pm   #3
paulsherwin
paulsherwin's Avatar
Very nice job.
Ekco used that plastic mesh in a lot of their early 50s models, and it often fails in various ways, so it's good to hear of a successful replacement.
paulsherwin is offline
Old 12th Jul 2021, 4:10 pm   #4
MurphyNut
MurphyNut's Avatar
Great job, I think the replacement mesh looks better than the damaged original, I never liked that plastic mesh, even murphy used it in a few sets and I think it cheapens the look.
Clive
MurphyNut is offline
Old 12th Jul 2021, 5:24 pm   #5
vinrads
Well done that is a good substitute for the broken grill ,as others have said it's awful stuff ,first class cabinet job ,Mick.
vinrads is offline
Old 27th Jul 2021, 10:13 pm   #6
mister valve
mister valve's Avatar
A very nice cabinet and grill restoration job.... The set looks brand new !
If you live, the chassis was dead; if you're dead, the chassis was live !!!!
mister valve is offline
Old 1st Aug 2021, 12:39 pm   #7
HowardB
HowardB's Avatar
Thanks for all the kind comments.
I've now sorted out the banana-shaped back panel using wooden reinforcements.
Don't know if this is standard practice, but it's certainly worked a treat on this radio.
The back is dead straight now.
ID:	238619   Click image for larger version
HowardB is offline
Old 2nd Aug 2021, 9:50 am   #8
AD360 Rob
AD360 Rob's Avatar
You've done an amazing job there, I have one of these sets too, mine needed the usual capacitors replacing to bring it back to life. They do sound nice and warm with good bass response.
AD360 Rob is offline
Old 10th Sep 2021, 1:21 pm   #9
telstar
I believe that Philco used that dreadful plastic grille on their 1950's radios. The model B23101 is an example.
Mike
telstar is offline
