24th Nov 2015, 8:52 am | #1 |
Valve base ID
Hello
Does any body know what these bases are for? Many thanks |
24th Nov 2015, 9:15 am | #2 |
Re: Valve base ID
hi,
there is an American 4 pin UX4, aEuropean F8 and the other one is probably a CRT base. |
24th Nov 2015, 9:16 am | #3 |
Re: Valve base ID
12 hole one for a 1950s/'60s CRT
4 hole one looks like UX4. One use was power connector for an HRO (from memory) as well as some (mainly pre-war) US valves Other - dunno. 2 out of 3 ain't bad Graham
Half my stuff is junk - trouble is, I don't know which half! |
24th Nov 2015, 4:09 pm | #4 |
Re: Valve base ID
The eight pin socket is the German Y8A type.
Here's an example, the EF12 pentode, Stahl rohre. There was also a ten pin socket, the Y10A. http://www.r-type.org/exhib/aaa1398.htm The twelve pin socket is the duodecal base used on CRTs such as the MW31-74 and many other 1950s CR tubes. The four pin socket is the type used on common rectifier tubes such as the type 80. DFWB. |
