19th Nov 2015, 7:07 pm | #1 |
Programming a TBP28L22N PROM
I have an old TBP28L22N PROM that I need copying and programmed into a new TBP28L22N PROM. Does anyone have the means to do this? I can supply the data sheet for it if needed. Thanks.
Regards, Dave. |
19th Nov 2015, 7:49 pm | #2 |
Re: Programming a TBP28L22N PROM
Is this a Texas Instruments device? The supported devices list for my ALL07A programmer includes a Texas instruments 28L22, which is a 20-pin, 256 * 8 bit Bipolar PROM. I think the 'N' suffix on your device probably just means it's a DIP packaged device.
Wait a couple of days and see if anyone just around the corner from you offers to help - thus negating the need to risk your original device in the post. Otherwise, PM me and I'll be happy to do it for you. I take it this is for a synthesised PMR radio of some sort? |
20th Nov 2015, 11:45 am | #3 | |||
@Sirius,
Thanks for your reply Yes, it is. Quote:
The PROM contains data for one quadrant of a circle, the other three quadrants use the same data which is manipulated so it goes in the right places! I asked Richard if he still had the capability to program a PROM but, unfortunately, he doesn't. Regards, Dave. Last edited by Amraduk; 20th Nov 2015 at 11:53 am. |
20th Nov 2015, 7:18 pm | #4 |
Thanks for the info - when / if you want to go forward with it just PM me and we'll take it from there.
...It's not entirely clear from your last post whether you do actually have a second, empty PROM. Your first post seemed to suggest that you did - I don't, I only have the programmer capable of reading and programming them but not, alas, any PROMs. If PROMS are a problem I could still read the code out of the PROM for you and programme it into a small EPROM (2716)? for which you could make an adaptor / converter / daughterboard which you could plug into the PROM socket of your second unit. It's a trick often used in ex-PMR radios which originally used Bipolar PROMS. That, plus your 'handle' was what led me to guess (incorrectly) that this was for a radio. |
20th Nov 2015, 8:22 pm | #5 | |||||
Regards, Dave. |
20th Nov 2015, 10:22 pm | #6 |
If you need faster access time than one chip can manage, why not use a bit-slicing technique? Stack up eight EPROMs, connect your bottom three address lines to a 74HC138 and use the outputs to drive the enable inputs of the 8 EPROMs. So you are effectively accessing eight bytes in one read cycle.
21st Nov 2015, 2:19 am | #7 | |
Hello Julie,
Regards, Dave. |
21st Nov 2015, 2:08 pm | #8 | |
I see your point about PROM vs. EPROM speed - I hadn't considered that. I'll await your PM when you have the PROMs. |
