1st Aug 2014, 4:54 pm | #1 |
Japanese AF114 Transistors ?!
Just acquired a set of Japanese ("Made In Japan") Juliette WT-6 (27Mhz) Walkie Talkies. Although in very good cosmetic condition & full working order, like all my gear, I couldn't resist opening them up.
Imagine my suprise to see 3x AF11X style transistors in each unit in the RX & TX stage : 1x 2SA70 (T.I.T.S. equiv given as an AF124) and a pair of AF114's. The 2SA70 is marked as Matsushita but the AF114's had no manufacturers name, although the AF114 was printed in Mullard style type . Suspecting the AF114's to be recent replacements I flipped the circuit board over and, on close inspection, the solder joints for the AF114's were undisturbed & original ! Any other examples of AF11X's use elsewhere abroad?
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
3rd Aug 2014, 8:42 pm | #2 |
Re: Japanese AF114 Transistors ?!
Philips and Matsushita were business partners around that time and may have done some cross-licensing and exchange of parts, so I'm not too surprised even though I haven't seen Japanese AF114's before.
4th Aug 2014, 12:09 am | #3 |
I've come across these before in Japanese imported sets and did think it to be a bit odd, but given the link with Philips it's beginning to make sense. I think i've also got an early 60's american built transistor set somewhere which I remember as being odd as it a couple of AF114's in it but can't be sure if they're original. the solder track did look to be undisturbed though. Will dig it out again and have another look.
5th Aug 2014, 8:16 pm | #4 |
I have made an even better discovery, albeit a somewhat rusty specimen it is indeed a TO7 package but this time with Japanese branding and the part number 2SA69.
http://alltransistors.com/transistor...ransistor=8715 |
6th Aug 2014, 2:46 am | #5 |
It makes me wonder... Did the Matsushita ones also suffer from tin-dendrites?
6th Aug 2014, 9:02 am | #6 |
I have seen similar ones in 1960s Japanese transistor radios, they were branded, if my memory serves me right, "TEN". There were similar "TEN" ones in TO-1 style cases in the audio stages..
6th Aug 2014, 1:52 pm | #7 |
It is the only one I have and I am pretty sure it is all right but a sample of one is not exactly representative.
20th Nov 2015, 11:32 am | #8 |
20th Nov 2015, 4:50 pm | #9 | |
Looking at the picture, I'd be suspicious of what I see in the seam. It could just be debris, of course. Simple enough to put a multimeter across all 3 electrodes and the can... |
20th Nov 2015, 5:29 pm | #10 |
The 2SA70 is the equivalent of the European OC170. Same casing with four wires.
http://www.radiomuseum.org/tubes/tube_2sa70.html The 2SA71 is the equivalent of the OC171 which was later replaced by the AF114 and AF115. http://www.radiomuseum.org/tubes/tube_oc171.html http://www.radiomuseum.org/tubes/tube_2sa71.html DFWB. Last edited by FERNSEH; 20th Nov 2015 at 5:37 pm. |
21st Nov 2015, 6:24 pm | #11 |
List of the transistors and diodes employed in the 1966 National (Panasonic) model RF1006L.
Note the European type diodes. Was there any technical links between Matsushita Electric and Philips? DFWB. |
21st Nov 2015, 10:03 pm | #12 |
21st Nov 2015, 11:19 pm | #13 | |
See https://en.wikipedia.org/wiki/Whisker_%28metallurgy%29
Don't forget this: http://nepp.nasa.gov/whisker/anecdot...tor/index.html Scary stuff |
22nd Nov 2015, 10:18 pm | #14 | |
