26th Oct 2014, 12:40 pm | #1 |
332 Bakelite Telephone Microphone issue
Hello all,
I have just purchased a new electronic microphone for a family friends GPO 328 telephone. I purchased it from AntiqueTelephones.com and currently have one in my 232 telephone working perfectly fine. I wired as per instructions, which didn't work, I then followed this guide (http://antiquephones.blogspot.co.uk/...-bakelite.html)which again didn't work, the Microphone simply is not being detected. I also swapped handsets with my 232 and vice versa, both handsets worked with the microphone on the 232, but as soon as I connect them to the 328 the Microphones no longer work, all I can do is hear a dial tone. I have no idea what else to try the wiring in the phone seems correct and nothing seems incorrect or out of place. Is there anything else to try? Thanks, Ryan |
26th Oct 2014, 3:12 pm | #2 |
Re: 332 Bakelite Telephone Microphone issue
Does your handset work with the traditional carbon inset mic?
Regds, Russell W. B. G4YLI. |
27th Oct 2014, 9:57 pm | #3 |
I blieve removing of the transmitter should break dial tone on the 328 (Wiring diagram N 428 here) http://www.samhallas.co.uk/repositor.../0000/N428.pdf
Some electronic replacement transmitters are polarity sensitive (Try to switch red and white wire) some demands a voltage of at least5 V across the transmitter. dsk |
28th Oct 2014, 4:34 pm | #4 |
I have tried that and it doesn't work on the 328. I have the same type of mic fitted inside of my Bakelite 232 and it works perfectly fine, and I have swapped both miss over they both work inside the 232 handset.
28th Oct 2014, 4:34 pm | #5 |
28th Oct 2014, 5:37 pm | #6 |
If the 328 has never worked, it sounds as though the problem lies elsewhere than the transmitter. As you are getting dial tone, it would appear that you have a loop. My first to check would be whether the dial-off-normal contacts across the transmitter are opening when the dial returns to normal (rest) position. If not, the transmitter will be shorted out.
28th Oct 2014, 6:57 pm | #7 |
Try to connect the handset direct to the line, just leave the common wire unused.
dsk |
