Old 22nd Apr 2019, 8:26 am   #1
its ur aerial
its ur aerial's Avatar
Default Home brew ATU
I intend to build a home brew aerial tuning unit for my home brew 80M AM TX O/P about 13 watts max.
I cant, find any suitable metal cases for it under £28, would it be acceptable to use plastic,or is screening of the ATU that important? I vaguely remember the ATU for the Joystick aeril in the 60`s being plastic.
73`s Ken G6HZG
Life is not Hollywood, life is Cricklewood.
its ur aerial is offline
Old 22nd Apr 2019, 9:15 am   #2
Default Re: Home brew atu
THe ATU can be an easy ingress route for domestic interference on receive. A metal case is wanted more than ever nowadays.
On transmit, to keep losses low, the cabinet needs to be big enough to be well spaced from inductors.
Balanced antennae are better for dodging interference, and they work best with a dedicated balanced ATU. Be sure you build an ATU suited to your antenna (I got this wrong and built a tour-de-force ATU that would win any construction competition, and I've never used it in anger!)
Radio Wrangler is offline
Old 22nd Apr 2019, 6:51 pm   #3
its ur aerial
Default Re: Home brew ATU
I think, buying some aluminum sheet and making a case is the way to go.
Old 22nd Apr 2019, 7:20 pm   #4
A big biscuit tin?
Old 22nd Apr 2019, 7:41 pm   #5
In the past I've used large plastic industrial IP68-rated enclosures but had them 'metal-sprayed' inside for screening [this is the modern version of the metallising used on valve-envelopes in the 30s and 40s].
The metal-spraying provides electrostatic screening but by virtue of being both non-magnetic and of a relatively high resistance it avoids the whole 'shorted-turn' or 'ferrite slug' detuning effects (which can sometimes be rather spectacular if you're running a couple of Kilowatts of RF up the spout).
Old 23rd Apr 2019, 7:16 am   #6
its ur aerial
Did think about a Biscuit Tin,but all this years Xmas assortment came in plastic containers.
I was also thinking about a IP65/68 enclosure and lining it with thin aluminium or tin plate.
Once upon a time, 10/6d in your pocket and a little swaray down Tottenham Crt Rd or Soho`s Lisle Street, had your chassis and cabinet sorted.
You could even purchase one of those Artistic Magazines for the more discerning Gent, while there.
Ken, G6HZG.
Old 23rd Apr 2019, 4:15 pm   #7
Mikeymushradio
Mikeymushradio's Avatar
I have N.O.S steel case 12" x 7" x 8" w x h x d if not too big.
Mike
Mikeymushradio is offline
Old 24th Apr 2019, 7:13 am   #8
its ur aerial
Mikeymusyradio,
metal box on offer sound ok, I have sent you a private message, thanks Ken
Old 25th Apr 2019, 11:27 am   #9
Mikeymushradio
Hi Ken
No P.M. at this end yet, just spotted your response.
Mike
Old 3rd May 2019, 7:47 am   #10
roberthewitt
I use 50mm adhesive copper tape for screening and veroboard ground plane..about £3.50 per roll
roberthewitt is offline
Old 3rd May 2019, 1:38 pm   #11
Andrew B
Andrew B's Avatar
Make the entire box out of ds copper clad board?
worried about the electrons entering the circuit and the smoke leaving
Andrew
Andrew B is offline
